585,931 active members*
3,655 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 cnc finished for now maybe
Page 1 of 53 1231151
Results 1 to 20 of 1045
    Heres some pics of my Harbor Freight X2 that I finished cncing recently.
    Had successful tests running Mach 2 and some engraving software.
    Now on to some improvements to the table travel, gonna see what I can get
    out of it because 3.5 x 7 isn't enough.(Wish I would have splurged for the X3
    instead, but oh well.)
    Plan on making a remote pendant from a usb thrustmaster joystick.
    Just bought a Dewalt laminant trimmer. Have one more bracket to make to
    mount it on the head for better engraving.
    Does anyone know if the X2 spindle can be turned on/off from Mach 2 using
    M3/M5 thru the controller?
    more stuff to come, Have autocad drawings for all the mounting brackets
    that I made to mount the steppers and such if anyone wants them.
    The DRO is one I made from a ShumaTech kit. http://www.shumatech.com/products/dro-350/index.htm
    later Hoss
    Attached Thumbnails Attached Thumbnails cnc mill progress 7.jpg   cnc mill progress 10.jpg   cnc mill progress 16.jpg   cnc mill progress 18.jpg
    Oct 2005
    612
    Very nice work there Hoss. Would be interested in the drawings for your conversion. Any chance of sending them in dxf format please. PM me and I will send my email address.
    cheers,
    Rod
    Perth, Western Australia
    Jan 2006
    357
    Nice work!, and to answer your question about the spindle, yes you can tun it off/on, you will need a bob to do it. I used a multifunction from cnc4pc, it is the only one I have expeience with but I love it!! no more standing waiting for the part to finish and then turning off the router, now I just load the gcode hit cycle start and walk away and do something else.
    Here's an update. Got another 3/4 inches of travel on the Y with a modification
    to the base. This gives me 4 7/8 x 8 1/4 travel for the X2.
    Better. I'll live with it for now till I run across an old cross slide to adapt to it.
    Maybe Little Machine Shop will get the X3 base for sale.Keep my eyes open.
    Have Fun, Hoss
    Attached Thumbnails Attached Thumbnails x2cnc table travel increase 1.jpg   x2cnc table travel increase 5.jpg   x2cnc table travel increase 7.jpg
    Hey Guys,
    Thought I would upload the dxf drawings I made for the stepper motor
    brackets and such. Hope they help you out.They are in inches.
    I used ballscrews and nuts from http://www.homeshopcnc.com/page3.html
    I got my thrust bearings and metal timing pulleys and belt from
    https://sdp-si.com/eStore/
    I made the drawings with Autocad but turbocad can open them too.
    Enjoy, Daniel (Hoss) Kemp
    Attached Files Attached Files
    A little more info for ya.
    The thrust bearings for xyz I bought at mscdirect.com http://www1.mscdirect.com/cgi/nnsrhm
    03380961 1.250X1.938X0.078 THRUST CAGE-NEEDLE ASSEMB
    03381142 1.250X1.937X0.032 THRUST WASHER-NEEDLE-FLAT (2)
    03380045 1.250X2.344X0.625 THRUST-BALL-BANDED MEDIUM
    03548591 3/8 X 11/16 X 9/32 SET THRUST BALL BEARING (2 sets)
    and the belt and metal timing pulleys I bought at Stock Drive Products and Sterling Instrument https://sdp-si.com/eStore/
    A 6A 3-16DF03708 .200 (XL) Pitch, 16 Teeth, Aluminum Alloy Timing Pulley
    A 6A 3-32DF03712 .200 (XL) Pitch, 32 Teeth, Aluminum Alloy Timing Pulley
    A 6B 3-060037 .200" (XL) Pitch, 60 Teeth, 3/8" Wide, Urethane Belt
    Later Hoss
    Oct 2006
    11
    Hoss, this looks like an excellent conversion! Please provide us with more information on the electronics such as the steppers, controller board etc. Thanks for the excellent information you have already provided.
    Hey nancygal,
    Here's some more info for you.
    I used a FET-3/Dynamo kit($329) from stepperworld.com
    http://www.stepperworld.com/FET3dynamo.htm
    It has a 3 axis controller with 190 in/oz stepper motors and accessories.
    I read on a post somewhere when I was researching it that these motors had enough torque to snap a 3/8 endmill so I figured that would do me just fine.
    If I was starting now, I would upgrade to their 4 axis controller for $50 more.
    Might come in handy for a rotary table or something but oh well.I'll post a couple pics of how I hooked them up. I used an old pc case to house it all. I hooked up the controller to the mill using pc DB9 serial cables(had to solder plugs to the motors and controller)so it's removable.I used S-Video cables to hook up the DRO to the scales. Get them at http://www.cablewholesale.com/
    You only need 6 wires to hook the motors up(instructions are included) so you
    could use MiniDin6 (PS/2) cables to hook them up for a tidier wire bundle on the mill.Again If I was doing it now,that would be easier to encase with a cable shroud to protect them. You can get the solderable DB9 connectors and cables at http://www.computercablestore.com/Se...CategoryID=212
    I got the scales for the DRO on Ebay from 800watt's store http://cgi.ebay.com/0-12-Y-AXIS-VERT...QQcmdZViewItem
    He has great prices but is pretty slow on shipping and bad at emailing you back. Might want to search Ebay for a different seller for the DIGIMATIC DIGITAL SCALE UNITS.
    well, hope this helps.
    Have Fun, Hoss
    P.S. This all takes a little bit of work but that's the FUN part, and It only cost me about 1/3 the cost of a turnkey cnc X2 I've seen for sale.
    Attached Thumbnails Attached Thumbnails cnc mill progress 3.jpg   cnc mill progress 5.jpg   cnc mill progress 14.jpg   cnc mill progress 15.jpg
    Apr 2005
    1268
    Hoss;
    Great job! I'm interested in your zaxis conversion and the rotating ball nut. I've been searching for such a design for my lathemaster. Tired of wearing out balls trying to move that 250 +lbs of mass.
    Unfortunately, I tried opening your dxf files with bobcad 21 but will little success. Can you email me at bsouthnow @ aol.com, copies of your zaxis drawings. I would really appreciate it!!!
    Very Best
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Apr 2005
    1268
    Hoss;
    Never mind the email for the files. I found an old copy of Turbocad pro (pre bobcad) and re-installed it for the drawings. Thanks! Would it be possible to share some detail on how you constructed the z-axis with bearing numbers and so forth?
    Thanks again.
    Bill
    billyjack
    Hey Bill,
    The bearings for the Z axis are in the post#6 above that I got at mscdirect.com.
    The location for the 2 big bearings can be seen in the cnc z axis mount.dfx above.You might need to use a shim (the same diameters as the lower thrust bearing)between the lower spacer and the thin thrust bearings to take up any backlash.The timing pulley is drilled and tapped to mount to the T shaped upper spacer that then slides down into the large thrust bearing.I'll work on a better expanded drawing for the parts used in cnc z axis mount.dxf.heres some pics of closeups of the Z axis from different angles.Hope it helps.
    Later Hoss
    P.S. here are jpgs of the drawings for anyone out there having trouble opening the dxfs.
    Attached Thumbnails Attached Thumbnails mill readout 1 crop .JPG   mill readout 2crop.JPG   mill readout 3crop.JPG   mill readout 11crop.JPG
    ball nut stop blocks rev A.jpg   ballscrews.jpg   ballscreww base mount.jpg   stepper motor couplings.jpg
    x axis stepper mount.jpg   y axis spacer.jpg   y axis stepper mount.jpg   z axis ballscrew mount.jpg
    z axis inner block.jpg   z axis spacer.jpg   z axis stepper mount.jpg   cnc z axis mount.jpg
    Apr 2005
    1268
    Thanks Hoss. I missed that dwg yesterday when I was playing around with Turbocad. It makes the whole setup a bit clearer. I'm still going to have to "study" on it awhile (like that say here in SC) and let everything soak in. Thanks for all the info!
    Bill
    (wedge)
    billyjack
    Hey Guys,
    Heres an update for the Z Axis.
    This pic should explain the assembly a bit better.
    Have Fun Hoss
    Looks nice! How long did it take?
    Gray
    My advice is worth less then you paid for it.
    Dec 2004
    1137
    Wow! This sure does help me see all the parts that go into a drive. I appreciate your sharing. I was wondering if you could so such a drawing for your Y-axis. I've heard of people adding thrust bearings (replacing the Y mount entirely) but I can't quite get my mind around it.
    Also, I was still a bit slow in understanding the whole bearing preload notion until I found this document http://www.timken.com/products/beari...Fs/Vol6No3.pdf hope it helps others and adds to the treasure trove that this thread is.
    Thanks again,
    Jay
    Here's an explanation for the Y Axis assembly as requested, check out the pic.
    Happy to help.
    keep an eye out, my control panel is coming together, will post pics when it's done.
    To answer Henry's question, I started ordering parts last April and worked on it off and on for a few months. Had it up and running in July/August.Still coming up with stuff to do to it, like the control panel and the engraver mount.Once this is done I'll turn my attention to my 7x10 minilathe. Have some cool ideas to try on it including cnc.
    Have fun, Hoss
    Dec 2004
    1137
    Excellent, as they say a marked up photo is worth a thousand words.
    Also, may I suggest a pulley conversion as your next project. It'll be my first one.
    Jay
    Hey Jay,
    the pulley conversion is on my list.
    Probably copy the one I've seen on littlemachineshop.com.
    Also the spindle lock is in progress, but I have to locate it on the front because my high speed engraver is going on the right side.
    The automatic toolchanger would be really cool but not something i'd
    probably get much use out of,that's really for production jobs, but may try to make it or something similar if i get bored. My 7x10 lathe will come before that.
    Noodling around with a couple conversion ideas for that. Then i could use it to make parts for the toolchanger easier.Yeah the first ballnut I loaded didn't go so well with little ball bearings bouncing all over the floor, but I found them all and got it right the second time.I left the cardboard tube in the nut and fed the ballscrew up from the bottom pushing the tube out the top.Much easier.
    keeps me busy and out of trouble.
    Later Hoss
    P.S.
    Here's a couple pics of some engravings I made with it.
    Attached Thumbnails Attached Thumbnails 24 car engraving.jpg   me engraving.jpg
    Nov 2004
    33
    Hoss... You made my day. I bought a X2 the other week and have been debating on how to go about CNCing it. Thanks a million!
    Eric
    Hey There,
    Have some more info for you.
    If you're looking for the 15/16-16 tap to thread the stop blocks
    and pulley, I got mine at Wholesaletool.
    http://www.wttool.com/product-exec/product_id/24817
    If you're looking to protect your wiring, I found some plastic
    split flex tubing at Lowes. They have 3/8 x 10 feet and 1/2 x 7 feet
    packages in the electrical dept. for less than $3. Autoparts stores
    carry the same kind of thing.
    Here's some pics showing my engraving tutorial.
    I've tried tons of different software to change an image into an engraving,
    but none gave me what I wanted in one simple program.Please let me know If
    you've found something that works nice and easy.This is what I've come
    up with.Might seem like a lot of steps, but I can go from a pic to gcode
    in about 10 min.Most of that is the tracing.
    Thanks Hoss
    Attached Thumbnails Attached Thumbnails engraving tutorial 1 (Large).jpg   engraving tutorial 2 (Large).jpg   engraving tutorial 3 (Large).jpg   engraving tutorial 4 (Large).jpg
  1. Almost finished
    By steeltoes in forum T-Slot CNC building
    Last Post: 03-10-2014, 03:11 PM
  2. It's finished
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 01-14-2012, 02:09 PM
  3. Almost Finished
    By Kencor1 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2010, 05:41 AM
  4. Finished at last (well almost!)
    By Ali Kat in forum DIY CNC Router Table Machines
    Last Post: 05-27-2009, 06:19 PM
  5. X2 cnc finished for now
    By hoss2006 in forum Benchtop Machines
    Last Post: 01-12-2007, 11:55 PM
