585,978 active members*
4,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 cnc finished for now maybe
Page 3 of 53 1234513
Results 41 to 60 of 1045
  1. #41
    Sep 2005
    140
    help with game pad
    Hoss
    Could you help me out with using keygrabber to program my game pad?
    Walt
  2. #42
    Feb 2006
    1187
    Good job Hoss!!, can,t wait to see the grinding attachment in use. Keep us posted.
  3. #43
    Hey Walt,
    Here's a little tutorial to setup Keygrabber for ya.
    Hope this helps.
    later Hoss
    Attached Thumbnails Attached Thumbnails keygrabber setup page 1 (Large).jpg   keygrabber setup page 2 (Large).jpg   keygrabber setup page 3 (Large).jpg
    Attached Files Attached Files
  4. #44
    Dec 2004
    1137
    Quote Originally Posted by hoss2006 View Post
    A little more info for ya.
    The thrust bearings for xyz I bought at mscdirect.com http://www1.mscdirect.com/cgi/nnsrhm
    03380961 1.250X1.938X0.078 THRUST CAGE-NEEDLE ASSEMB
    03381142 1.250X1.937X0.032 THRUST WASHER-NEEDLE-FLAT (2)
    03380045 1.250X2.344X0.625 THRUST-BALL-BANDED MEDIUM
    03548591 3/8 X 11/16 X 9/32 SET THRUST BALL BEARING (2 sets)
    and the belt and metal timing pulleys I bought at Stock Drive Products and Sterling Instrument https://sdp-si.com/eStore/
    A 6A 3-16DF03708 .200 (XL) Pitch, 16 Teeth, Aluminum Alloy Timing Pulley
    A 6A 3-32DF03712 .200 (XL) Pitch, 32 Teeth, Aluminum Alloy Timing Pulley
    A 6B 3-060037 .200" (XL) Pitch, 60 Teeth, 3/8" Wide, Urethane Belt
    Later Hoss
    Hoss, I'm considering following your plans and am working to understand them in depth. One thing that is eluding me is the use of all the parts above. Specifically you specify two (03381142 1.250X1.937X0.032 THRUST WASHER-NEEDLE-FLAT (2)) thrust washers. However in the z axis mount.bmp you only use 1 ("thrust bearing i.d. 1.25 o.d. 1.938 width .110). Where is the second washer used?
    Secondly, I think it's safe to assume that you did not replace the bearing assembly on the X-axis. Other than that I think I have it
    Finally, did you buy a 15/16 - 16 tap?
    Jay
  5. #45
    Aug 2006
    102
    Smile toolchanger
    have you got and will you share any info you have on the proposed auto tool changer? after the in depth descripitions and the workmanship i have seen so far i feel your the man to go to. thanks in advance greg
  6. #46
    Hey Jay,
    In the original setup. I only used 1 needle flat between the thrust bearing and
    the aluminum mounting plate, but added a second one on either side of the bearing to give the bearings a hardened surface on both sides to ride on. I
    figured the bearings might wear into the lower flange since it 's not hardened steel. This cut down on the amount of shims I needed to just .005.
    The shims just compensate for tolerances of the machined parts.The shaft of Flange C could be left a little long initially (.050 maybe) and faced to size when all the parts are put together instead of shimming. Like I always say, It's easier to remove material later than try to add to it.
    You assumed right, the X axis bearings are stock.
    I did get an import 15/16-16 tap at wholesale tool.
    http://www.wttool.com/product-exec/product_id/24817
    Later Hoss
  7. #47
    Hey Greg,
    If I come up with an auto tool changer, I will certainly show it off, but I haven't started anything yet. I downloaded a pdf from Little Machine Shop of the one they are selling for $1000.
    http://www.littlemachineshop.com/pro...gory=879658189
    Looks really cool, but way too much for me to spend on something I really wouldn't need unless I got into making production parts to sell.( like maybe a kit for an auto tool changer, Hey maybe someday)
    later Hoss
  8. #48
    Hey Gang,
    Had a problem with the X2's circuit board so I was looking for a replacement.
    Didn't want to spend $99 at Grizzly or $120 at Little Machine Shop.
    http://www.littlemachineshop.com/pro...211&category=6
    I found a 130 VDC 8 AMP MOTOR CONTROLLER BOARD used in treadmills for $30 at http://www.surpluscenter.com/item.as...tname=electric
    It works just as well as the original, even have to cycle the power switch(4.7k Potentiometer) back to zero when you hit the E-stop to get the motor to come back on just like the original. The schematic for the circuit board calls for a 5k Pot to vary the speed but the 4.7k on the mill works (just shuts off a little slower than before.) Use the E-Stop to be SAFE!
    Here's some pics
    later Hoss
    Attached Thumbnails Attached Thumbnails x2 circuit board  2 (Large).JPG   x2 circuit board replacement 2 (Large).JPG   x2 circuit board replacement 10 (Large).JPG   x2 circuit board replacement 12 (Large).JPG
  9. #49
    Hoss,
    Nice work, once again a very informative post by you! I always look forward to reading your post. It's an adventure, you never know what you get.
    Bill
    Bill
  10. #50
    Thanks Bill,
    It's great to get good feedback.
    Here's a couple updates.
    My Control panel is finished with my DRO attached.
    The Surface Grinder attachment is nearly done.
    Had to pirate a speed control from an old router for it.
    The speed at the wheel was 10,680 RPM. Way too fast for the
    4100 RPM 6 x 1/2 grinding wheels I have coming. The speed control
    lowers it to 3600 RPM.
    I checked the speed with a Digital Laser Photo Tachometer I found on Ebay.
    Check out EZ-Outlet http://stores.ebay.com/EZ-OUTLET
    Only $23, it's very accurate and Non-Contact.
    My wheels should be here next week, I'll let you know how it cuts.
    Also have a book coming about building an EDM (Electrical Discharge Machine)
    Looks like a cool project to keep me busy an out of trouble.
    Later Hoss
    Attached Thumbnails Attached Thumbnails control panel with dro 3 (Large).JPG   control panel with dro 4 (Large).JPG   surface grinder attachment progress  16 (Large).JPG   surface grinder attachment progress  23 (Large).JPG
  11. #51
    Mar 2006
    113
    Hey Gang,
    Here's some pics
    later Hoss
    Hoss,
    I just bought a new board from Grizzly....
    Would you mind indicating which wire went where from the standard board to the new treadmill configuration. I tried to figure it out from the photos but I am totally lost.
    I gotta say you do some amazing retrofits.
    Dan.
  12. #52
    Hey Dan,
    Here's some info that should clear up the circuit board replacement.
    The wiring diagram is the only one I could find that's close.
    It's actually for the Harbor Freight 7x10 lathe 250Watt , but there isn't much
    of a difference for the wiring other than the reversing switch for the motor.
    Also guys, check out my webpage at http://www.hossmachine.com
    It's a work in progress. I'll eventually have LOTS more info loaded there.
    Later Hoss
    Attached Thumbnails Attached Thumbnails hf 7x10 circuit schematic.jpg   x2 circuit board replacement diagram (Large).jpg
  13. #53
    Mar 2006
    113
    Thanks, you da man!
    Dan.
  14. #54
    Here's a little update on the surface grinder attachment.
    Up and running now. Slowing the RPM down to 3600 really cuts down
    on the power but hey it only has to remove .001 or .002 a pass.
    Have since found a Router Speed Control at Harbor Freight that would have been easier than pirating one from one of my old routers. oh well.
    http://www.harborfreight.com/cpi/cta...emnumber=43060
    here's some pics
    later Hoss
    http://www.hossmachine.com/
    Attached Thumbnails Attached Thumbnails surface grinder initial setup 1 (Large).JPG   surface grinder initial setup 4 (Large).JPG   surface grinder initial setup 14 (Large).JPG
  15. #55
    Sep 2006
    881
    ok, i'm gonna show my ignorance, but what would i use a surface grinder for?
    why wouldnt i just mill what i want smooth?
    Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
  16. #56
    Mar 2006
    113
    you will never mill as smooth, flat, or accurate a surface as you can grind.
  17. #57
    I agree with you dfurlano,
    And you also aren't going to mill a hardened piece of steel or a very thin
    one like this special washer I needed.
    I will use the grinder for making or modifying
    123 blocks, parallels, planer knives, angle plates, V-blocks etc.
    Hope this helps.
    Later Hoss
  18. #58
    Sep 2006
    881
    really?!?!?! i had no idea...learned something new today..
  19. #59
    You being a smartass project5k?!?!?!
    Hoss
  20. #60
    Hoss,
    Man were do you come up with these cool little projects, I love them!
    One question if I may, were did you get the magnetic grinding plate? (I think thats what it's called)
    Thanks Again
    Bill
    Bill
  1. Almost finished
    By steeltoes in forum T-Slot CNC building
    Last Post: 03-10-2014, 03:11 PM
  2. It's finished
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 01-14-2012, 02:09 PM
  3. Almost Finished
    By Kencor1 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2010, 05:41 AM
  4. Finished at last (well almost!)
    By Ali Kat in forum DIY CNC Router Table Machines
    Last Post: 05-27-2009, 06:19 PM
  5. X2 cnc finished for now
    By hoss2006 in forum Benchtop Machines
    Last Post: 01-12-2007, 11:55 PM
