585,743 active members*
4,948 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X2 cnc finished for now maybe
Page 37 of 53 27353637383947
Results 721 to 740 of 1045
  1. #721
    Quote Originally Posted by BobWarfield View Post
    This will be interesting.
    RE backlash, you can look for relatively backlash free drives on eBay from Bayside and the like. Harmonic drives in other words.
    This thread on hypocycloid drives is also quite interesting:
    http://www.cnczone.com/forums/showth...ht=hypocycloid
    You have to get past the earlier posts to get to the hypocycloids.
    Will you be adding brakes to the axis? Probably not needed for a mill of this size I guess.
    Cheers,
    BW
    Cool lookin stuff for sure, Zoidberg was chock full of design ideas.
    Could never spend that kind of money for an accessory for a hobby mill.
    Maybe with the VMC I get for Xmas this year.
    Later, Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #722
    Nov 2003
    244
    Led lighting and reflective sensor
    Hoss,
    I'm working on an attachment similiar with led lighting and a reflective sensor in one housing eliminating the need for the disc all together.
    Let me know what you think.
    ...He who makes no mistakes makes nothing! ...
    Tom
  3. #723
    Quote Originally Posted by tpworks View Post
    Hoss,
    pretty cool, you could probably market that.
    nice and low profile too.:cheers:
    Hoss
  4. #724
    Haven't been totally slacking off on the trunnion table.
    Just 1 1/2 more parts to make this weekend and I can bolt 'em all together.
    I'll post the prints later for the rotary table mods to convert it to a simple 4th axis.
    Hoss
  5. #725
    Nov 2003
    244
    led/encoder
    Here's a few pics of the prototype almost done. I added a few more led's, 7 wasn't quite enough light so I tripled it to 21.
    Tom
    Attached Thumbnails Attached Thumbnails 100_0299.jpg   100_0297.jpg   100_0300a.jpg
    Tom
  6. #726
    Mar 2009
    1114
    I assume this is to be mounted on the bottom side of the head. With that i also assume you would need to drill and tap, to mount it?
  7. #727
    Nov 2003
    244
    led/encoder
    Correct and correct.
    Tom
  8. #728
    Looking very cool Tom, very bright.
    Played around some more with Alibre and made a model of the rotary table.
    Files are too large to upload the pdf or STL here. Don't have the internals done anyhow.
    Pics though.
    Hoss
    Oops, back to the drawing board, just noticed I forgot the mounting slots in the base.
    Attached Thumbnails Attached Thumbnails trunnion table rotary.jpg   trunnion table rotary002.jpg   trunnion table rotary003.jpg
  9. #729
    Jul 2003
    281
    Quote Originally Posted by hoss2006 View Post
    Pics though.
    Hoss
    Great job Hoss! How fast can the table rotate in RPM? Could you use it for a Lathe and 4th Axis?
    Bob A:cheers:
    www.cad2gcode.com
  10. #730
    [QUOTE=Bob Adams;643089]Great job Hoss! How fast can the table rotate in RPM? Could you use it for a Lathe and 4th Axis?
    Bob A:cheers:
    Hey Bob,
    Nope, not in the traditional sense.
    This rotary table has a lower ratio than some at 36:1 but that would still mean to get
    a decent enough turning speed of say 500 rpm, the drive motor would have to spin at 18,000 rpm.
    I will be doing some "turning" with it using an endmill though.
    It's main purpose will be positioning.
    I already have a "turning" 4th axis as you know.
    Hoss
  11. #731
    We have a trunnion table.
    Wound up with an 11 x 5 inch work area, could mount a 6 inch wide part and still rotate to 90 degrees as is.
    Can't wait to take it down and hook up the old 4th axis motor and try making something with it.
    Should be cool.
    Also made a little video for newbies that ask about "manual" control with CNC.
    Shows drilling a couple holes using jog buttons and MDI input.
    Excuse the poor webcam quality.
    Hoss
    [ame="http://www.youtube.com/watch?v=NC1wNzHHiEQ"]YouTube - Manual Drilling with CNC[/ame]
    Attached Thumbnails Attached Thumbnails IMG_4455_800x600.jpg   IMG_4458_800x600.jpg   IMG_4460_800x600.jpg
  12. #732
    Posted a video in response to an email question about drilling peck cycles.
    I made myself a couple little text files that explain the codes a long time ago
    but the video shows it real time.
    Just though I'd pass them along.
    Hoss
    [ame="http://www.youtube.com/watch?v=lF71Cz634lI"]YouTube - G73 and G83 Peck Drilling Cycles[/ame]
    Attached Files Attached Files
  13. #733
    Mar 2009
    1114
    Trunnion looks nice, what are you dong about backlash?
  14. #734
    I added thrust bearings and threads to the drive shaft to be able to adjust it out there
    and use the setscrew on the side of the casting to take it out of the worm gear.
    Hoss
  15. #735
    I had an email question from someone that wanted to use any of their tools as a tool probe.
    They have the part isolated and wanted to be able to find the edge no matter which tool is in spindle not just with a dedicated tool probe.
    I edited the codes for my buttons so that it will compensate for the tool diameter that is reported in the tool table.
    You can input the diameter yourself if you wish.
    The auto corner and auto edge finding buttons were changed.
    A vice could be isolated from the table and clamps with some thin delrin or HDPE sheet, etc.
    I'll post the codes tomorrow after I double check them on the mill, I just used the PC to simulate for this video.
    Hoss
    [ame="http://www.youtube.com/watch?v=G3aFUXlh6uk&feature=channel_page"]YouTube - Auto Tool Probing with Tool Diameter Input[/ame]
  16. #736
    Feb 2007
    4553
    Question
    Hoss,
    Awesome job!
    Where can we find the new screens and code?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  17. #737
    May 2009
    Thanks for the nice demonstration and presentation through "youtube".
  18. #738
    Here ya go jeff and gary,
    The codes have all been checked on my mill and are good to go.
    You can now use any diameter tool you want for the probe just by entering the dia. in the DRO.
    The videos show my tests using the trunnion table isolated from the rest of the mill.
    Only took some thin sheets of plastic.
    Thanks for asking Gary, this turned out pretty cool.
    Hoss
    [ame="http://www.youtube.com/watch?v=D234Vz2m-Rs&feature=channel_page"]YouTube - Auto Probing with Tool Diameter Input Part A[/ame]
    [ame="http://www.youtube.com/watch?v=4xatreuCGE4&feature=channel_page"]YouTube - Auto Probing with Tool Diameter Input Part B[/ame]
    [ame="http://www.youtube.com/watch?v=x0TmClbDaUA&feature=channel_page"]YouTube - Auto ID and OD Probing with Tool Diameter Input and DRO Output[/ame]
  19. #739
    The trunnion table is mounted up now and indicated in but that's about as far as I got this weekend.
    When i'm not concerned with making it isolated it'll be easier to mount using the pins in the tooling plate to line it up.
    This video is just a quick run through.
    Hoss
    [ame="http://www.youtube.com/watch?v=PaQb-eW_xCM&feature=channel_page"]YouTube - Trunnion Table Intro[/ame]
    Attached Thumbnails Attached Thumbnails IMG_4528_800x600.jpg   IMG_4530_800x600.jpg
  20. #740
    DOH! Forgot to upload the new codes, didn't I.
    here ya go.
    Hoss
  1. Almost finished
    By steeltoes in forum T-Slot CNC building
    Last Post: 03-10-2014, 03:11 PM
  2. It's finished
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 01-14-2012, 02:09 PM
  3. Almost Finished
    By Kencor1 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2010, 05:41 AM
  4. Finished at last (well almost!)
    By Ali Kat in forum DIY CNC Router Table Machines
    Last Post: 05-27-2009, 06:19 PM
  5. X2 cnc finished for now
    By hoss2006 in forum Benchtop Machines
    Last Post: 01-12-2007, 11:55 PM
