Originally Posted by
louieatienza
I don't think Aspire would suit you for necks. The big deal now for CAD/CAM is Fusion360. I haven't used it yet, but the price is right, and the modeling looks pretty easy enough. If you purchase CAD/CAM capable of modeling necks it would cost more than your CNC budget.
One consideration if you do intend to machine necks is how you intend to do them. You can do them easily on the flat if you build up the neck heel afterwards. Otherwise you'd need about 4" for the stock, another 1/8" or so for rapids plane, and the tool needs to be at least 4" flute length. Add a fixture, and extra clearance for comfort and you'll find there are not many machines with 9-10" of Z travel. On the flat, machining the sides of the neck, you probably could get away with 7-8", depending on headstock design. If you build necks using laminations, then it's easy to profile cut the parts and glue them together, but then you'll face the challenge of machining that part afterwards, unless you intend to shape it manually (and I do that a lot.)
