585,951 active members*
3,918 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
Page 2 of 3 123
Results 21 to 40 of 57
  1. #21
    Mar 2013
    26
    Re: DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
    Quote Originally Posted by jalessi View Post
    Does the motor lock up when the driver is powered?
    yes, motor locks up.
  2. #22
    Mar 2013
    26
    wiring
    Attachment 315060
    and this is very strange signal that is coming from the driver B+ B- wires
    I dont move any axis here..
    Attachment 315062
  3. #23
    Feb 2007
    4553
    1: Please backup the plugin directory in Mach3.
    2: delete all plugins
    3: install the attached plugin & configure.
    4: report back outcome
    Attached Files Attached Files
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  4. #24
    Feb 2007
    4553
    Be careful you don't blow up the driver accidentally shorting the loose wires on B- B+
  5. #25
    Mar 2013
    26
    no change at all.
    I tried "step low active", configured plugin buffer time (400 and 100)
  6. #26
    Mar 2013
    26
    and I am trying older mach3 - Version R3.042.020
  7. #27
    Feb 2007
    4553
    Question Re: DDUM4 V1.0 and DDCM6V5.0 not working with M542T driver
    There are several versions of the .dll depending on the card.
    Do you have this screen with the setting in the attached image?
    Jeff...
  8. #28
    Mar 2013
    26
    Attachment 315088
    this is that I get
  9. #29
    Feb 2007
    4553
    Didn't the vendor that you purchased it from provide the correct dll file for the DDUM4 V1.0?
    Jeff...
  10. #30
    Mar 2013
    26
    Actualy, it is very strange. CD with manuals and plugins contained video files showing how to install and setup mach3, but it was different from manual pdf file..
    Anyway, I tired all settings, but nothing worked.
    plugin file is version 1.0a in manual and video, but in CD it is version 2.0a
    I will ask them if they have correct file..
  11. #31
    Mar 2013
    26
    but I dout it will change anything because the other DDCM6V5.0 card that I tested had plugin version 2.0a as in manual. And it didnot work.
    Anyway, I have sent it back to vendor.
    I have left with this DDUM4V1.0, but I guess not for long
  12. #32
    Feb 2007
    4553
    Archsakas,
    Sorry we haven't made any progress.
    Unfortunately the original developer of the Digital Dream DSP is out of business and whats left are a boatload of clone products and impostors.
    Have a most awesome evening!
    Jeff...
  13. #33
    Mar 2014
    1131
    Quote Originally Posted by archsakas View Post
    I connected exactly as in manual, that is common positive wire (+dir and +puls) and separate negatives to -dir and -puls. It says in mamual there is no EN signal.
    On DDCM6V1 Later I have found that then I set "step low active", motors works but not properly.
    ON DDUM4V1 there are separete 4 wires for step and dir +and -. I could not wire them wrong..
    Išsiųsta naudojantis Nexus 7 Tapatalk 4 Lt
    Does this apply to DDSM6V5.0 200khz version too? Will it not work with the latest Mach3? Because I am about to order one.
    Archsakas,
    Try using version 3.042.040 of Mach3, the newer versions are not compatible with USBmove.dll version 2.01.9
    ftp://machsupport.com/Mach3/
    Jeff...
    Sent from my GT-I9300 using Tapatalk
  14. #34
    Mar 2013
    26
    In my opinion, it is the same crap...
  15. #35
    Feb 2007
    4553
    Unfortunately, I agree.
    Jeff...
  16. #36
    Mar 2014
    1131
    Thanks for the early warning.
  17. #37
    Mar 2013
    26
    Hello again, finally I got it working with TB6560 3A driver!!! i guess it will work with TB6600 driver aswell, which I am still waiting from china and bought it only for testing purposes..
  18. #38
    Jun 2014
    777
    By working do you mean moving? The one I had moved the machine straight away. What it did afterwards was much more worrying.
  19. #39
    Mar 2014
    1131
    You got the 6 axis one working or 4? What mach3 version are you using?
  20. #40
    Mar 2013
    26
    Yes, I have motor moving on DDUM4 V1.0 card with the latest mach 3.043.066.
    I dont have 6 axis card at the moment, so I cant say anything about it.
Page 2 of 3 123
  1. DDum4 v1.0 settings for spindle PWM and mist/flood
    By bmwdriftpower in forum Controller Cards
    Last Post: 04-01-2016, 07:03 PM
  2. My first Driver not working
    By ghadden in forum CNC Machine Related Electronics
    Last Post: 03-01-2012, 10:24 AM
  3. HobbyCNC Driver Board Not Working
    By Barefooter in forum Hobbycnc (Products)
    Last Post: 02-12-2012, 09:56 PM
  4. received the driver board, not working?
    By elektroda in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-24-2011, 09:32 PM
  5. Mach3 Driver Test not working
    By Beefy in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2011, 06:21 PM
