585,987 active members*
4,210 visitors online*
    Apr 2016
    Laser engraver help
    I am trying to refit my flashcut sherline mill with a laser cutter and trying to configure the spindle controller to turn of after every move. Is there a place in the setting to set that up or do i have to use a gcode edit in my files?
    Aug 2007
    9
    Re: Laser engraver help
    I don't recall seeing that in the regular FC setup. I would think that command would need to be inserted into the gcode either by hand or in your CAM program. How are you generating your gcode?
    Aug 2007
    9
    I was just thinking...if you have the laser head retract between moves you could rig up a switch on the Z axis that could in turn connect to one of the logic inputs. Then in FC I believe you can assign that input to a spindle or relay control. Certainly not the most elegant way to do it, but it might work. This way when your code tells the Z axis to go to its safe Z when a move is done, the switch would be activated. At the new location when the Z drops into position the switch de-activates and the laser comes on. (or vice-versa). Depending on your laser you might be able to wire the switch directly to it.
    Dave
  1. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
  2. Hot!!!! Dissount nowEconomical Co2 laser engraver/ cnc laser cutting machines
    By Lasersolution in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-13-2014, 05:57 PM
  3. wklaser (Gweike laser) 2011 No. 1 Hot Product--6040N laser engraver display
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2014, 02:25 PM
  4. Replies: 0
    Last Post: 07-05-2013, 08:44 AM
  5. CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 09:44 PM
