Hello friends.
I build a CNC with a version 2.62 CNC Mach 3 software, now I have updated the machine to the 3.042.020 version Mach 3 but with the same controller and connections now I have the following problem:
CONFIG SWITCH.- I share the same 5 switch for home limits and limit works (2 for X axis, 2 for Y axis a nd one for Z axis).
Before with the 2.62 version Mach3 the Auto home function ran good and also the limits switches, now since I updated the version to Mach 3 3.042.020 the Auto home return run good if I press 'REF ALL HOME' but the switches doens't run in a working proccess if I press any switch.
X HOME and Limits switch are plugged into 15 port
Y HOME and Limits switch are plugged into 13 port
Z HOME and Limits switch are plugged into 12 port
IN Auto detect process in Config ports, when I start the proccess the system recognize all the switches. But in working progress the limits switches doesn't run.
Please help. Thanks.
