MASTERCAM X8-X9 2D & 3D ADVANCED MILL & LATHE / C-Y AXIS, SOLIDS & MULTI-AXIS COMPLETE VIDEO TUTORIAL BUNDLE
Includes Mastercam X8 & X9 Home Learning Edition
Mastercam X8-X9 2D MILL video tutorial brought to you by VTP (Video Tutorial Professionals). Using this video tutorial you will learn step by step using our programming flowchart how to design and program parts in mastercam. Starting with geometry creation, you will learn how to create drilling, milling, facing and contour cutting operations as well as 2D HST, FBM Mill & Drill and importing solidworks parts into mastercam. Included All Exercise Files and Mastercam X9 Home Learning Edition to help you get started on your programming journey
Mastercam X8-X9 3D MILL video tutorial brought to you by VTP (Video Tutorial Professionals). Using this video tutorial you will learn the advanced features of milling, focused on the surface geometry creation, stock model creation, and surface roughing and finishing features. This tutorials goes thru all the 3D HSS machining features in detail using 6 very well detailed exercises. All Exercise Files and Mastercam X9 Home Learning Edition are included in the DVD to help you advance your knowledge in mastercam to the next level.
Mastercam X8-X9 LATHE / C-Y AXIS video tutorial brought to you by VTP (Video Tutorial Professionals). Using this video tutorial you will learn step by step using our programming flowchart how to design and program parts in mastercam. Starting with geometry creation, you will learn how to create roughing, finishing, facing, threading, grooves, and cuttoff operations as well as C-Axis facing, cross contour, and drilling. You will also learn Stock Transfer, flip & advance. Included All Exercise Files and Mastercam X9 Home Learning Edition to help you get started programming right away.
Mastercam X8-X9 Solids video tutorial brought to you by VTP (Video Tutorial Professionals), in our 2nd generation Mastercam video tutorial. Using this tutorial, you will learn all the necessary features for solid creation. Includes how to make extrude Boss & Cut Solids, Levels, Boolean Add & Remove, and new X8 features such as new user interface, Push-Pull, Live Preview, Hands-on drag control and much more. Includes a full chapter introduction on designing as well.
Mastercam X8-X9 Multi-Axis 4/5 Axis video tutorial brought to you by VTP (Video Tutorial Professionals). Using this video tutorial you will learn the how to get started setting up and machining in 4 & 5 Axis. The DVD will go over Axis Substitution, Drilling & Circle Milling in 4/5 Axis, Rotary 4-Axis, Curve & Swarf 5-Axis as well as Flow and Multisurface 5-Axis. All Exercise Files and Mastercam X8 & X9 Home Learning Edition are included in the DVD to help you advance your knowledge in mastercam to the next level.
Pre-requisite: MASTERCAM X8-X9 MILL & SOLIDS
SPECIFICATIONS:
Resolution 1280x720 HD QUALITY MC Version Made In MasterCAM X8 & X9 System Windows XP, Vista, Win 7, Win 8 & Mac CD/DVD DVD (Only Playable on computers or any DVD that plays .mov files) Video Player QuickTime & WMP (For High Quality 1280 x 720 HD) Sessions/Hours 408 Sessions and over 40 hours of videos Includes - All Files and Models From all video tutorials - Mastercam X8 & X9 Home Learning Edition Package All DVDs come with DVD case Fully Protected Format Software Menu to easily navigate thru your Lessons
Mastercam x8 x9 2D 3D Mill Lathe Solids Multi Axis Video Tutorial Bundle | eBay
