Hello, I have an Estop on my control box for my mill that is switching 5volts. Well now I want the same Estop switch to shutoff my WJ200-022SF VFD on GS1 and GS2. The problem is 24VDC is on GS1 and GS2. So what type of Estop switch is out there so that I can put 5 volts and 24 volts through the same switch to shut the VFD down and Mach3 at the same time? The situation I have is, I have an engraving spindle I am putting on my mill that will be run by the WJ200 VFD and will not be controlled with Mach3. So when Mach3 is moving X,Y,Z axis I want to be able to hit the Estop button and shut both the VFD and Mach3 down at the same time.
Any suggestions would be helpful,
Jeff
