585,749 active members*
3,875 visitors online*
    Apr 2016
    33
    Exclamation Control Panel running, Machine is not..HELP
    I am trying to setup a computer to run our CNC machine. I am more techy than machinist (BF is the machinist but knows nothing about computers). I had to add two new ports to the computer to connect the plasma. Everything is loaded on the computer. When I launch the Mach3 plasma and pull up a g-code design it does run on the control panel. But it will not make the machine move. I thought it was due to the new ports I added. I do seem the listed under the device manager (under other device and not under ports (COM & LPT) but I can not seem to get anything to run. I am not sure if its the way I installed the software or that I installed the ports incorrectly. Any help would be fantastic!
    Feb 2016
    381
    Re: Control Panel running, Machine is not..HELP
    Ports need installing correctly Com LPT1 etc and then get address from device properties to ensure correct address is used in Mach3
    Apr 2016
    33
    Quote Originally Posted by Louis_Cannell View Post
    Ok so it looks like my ports are not installed correctly is my guess.
    I will look into reinstalling them and see if that works.
  1. Control Panel running, Machine is not..HELP
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-04-2016, 09:09 PM
  2. Replies: 1
    Last Post: 02-19-2014, 02:19 AM
  3. DIY CNC Milling Machine Control Panel for EMC2
    By gschoep in forum LinuxCNC (formerly EMC2)
    Last Post: 02-23-2011, 05:10 AM
  4. Hyundai HiT 20M Machine Control Panel
    By timbillyosu in forum Hyundai Kia
    Last Post: 01-06-2011, 07:41 PM
