585,602 active members*
3,614 visitors online*
Results 1 to 6 of 6
    Apr 2005
    35
    Setup question
    I am having trouble setting up my picstep with Mach3.
    My hope is to do 1/4 stepping. If I am using firmware v2 then I should have a shunt on J1 but NOT J2 ?
    John W.
    John W
    http://home.comcast.net/~pwprojects
    Apr 2005
    35
    I obviously don't understand schematics or something but when I look at the "schematic v4.0" I see this for the step settings
    J1 J2
    0 0 - 1/8 step (I assumed this meant no shunts)
    0 1 - 1/4 step
    1 0 - 1/2 step
    1 1 - full step (and this meant both jumpers shunted)
    As I understand it this was modified to this with v2 of the firmware
    J1 J2
    0 0 - 1/16 step (I assumed this meant no shunts)
    0 1 - 1/8 step
    1 0 - 1/4 step
    1 1 - 1/2 step (and this meant both jumpers shunted)
    Heres my problem, I seem to get 1/16 stepping with both shunts on and 1/2 stepping with no shunts on.
    But wait it gets trickier I get 1/4 stepping with a shunt on J1 and no shunt on J2 but if the above 1/16-1/2 step observation holds shouldn't the stettings be the opposite of what I observed for the 1/4 step
    So I guess the first question is: Does "1" mean shunt or no shunt?
    Is it even possible to screw up assembly in such a way that some but not all the settings are backward and then repeat it 3 times?
    Maybe I just need some sleep and some fresh eyes.
    Any thoughts are welcome,
    John W
    John W
    Nov 2006
    26
    Usually a '1' indicates a high logic level (or +5v) on an input. In the picstep design I think there are resistors pulling the inputs up (which makes them high by default) and the jumpers short the inputs to ground (or '0') so probably '0' is jumper installed. You could probably verify this by looking at the source code.
    I can't understand why the other two settings would be reversed though.
    Jan 2006
    357
    dtman2 is correct 0 = no jumper 1 = jumper
    Apr 2005
    35
    I'll have to relook at my jumpers again.
    Not to belabor the point but dtman2 said[
    ...and the jumpers short the inputs to ground (or '0') so probably '0' is jumper installed
    while GaryCorlew said
    ...0 = no jumper 1 = jumper
    This would seem to be opposite
    John W
    Jan 2006
    357
    Ugg your right, 0 = jumper 1 = no jumper
