584,858 active members*
4,594 visitors online*
    Sep 2011
    474
    PathPilot + Mesa 5125...closed loop
    I have this setup with the new Tormach controller and 3ph steppers. I know both LinuxCNC and the Mesa 5i25 are compatable with encoder feedback and true closed loop. Has anyone tried this? Seems trivial on the "add encoders to the steppers" end, but what would need to happen on the electronics/ programming side to make this happen?
    As always,
    Thanks guys
    Oct 2010
    1189
    Re: PathPilot + Mesa 5125...closed loop
    my closed loop works by electronics where linuxcnc just now the encoder values but the liogic is done by electronics i guess you want linuxcnc to do the correction i have seen an wiki where the guys use a glass measurement to correct their backslash that would be my startpoint
    Gesendet von iPad mit Tapatalk
  1. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  2. CNC conversion typically open loop or closed loop?
    By foobar42 in forum Benchtop Machines
    Last Post: 10-30-2009, 01:21 AM
  3. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  4. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
  5. Closed Loop Driver vs. Closed Loop Computer
    By ojibberish in forum Gecko Drives
    Last Post: 06-08-2004, 05:30 PM
