585,758 active members*
4,114 visitors online*
Thread: UCCNC Help
    Oct 2006
    41
    UCCNC Help
    Hello
    I have been using Mach3 with cnc drive - HDBB and Dugongs on a cnc knee mill professionally for the past 6 years, 6 days a week all with the help of Balazs ( He RDP into my mill and tuned all 3 axis and configured mach3 ) . I have finally dropped mach3 just was getting buggy - but I did like the configuration which I imported into UCcnc -
    The tools offsets are a bit confusing - I am use to a touchoff tool a #1 and all other tool offsets measure from it - I do not use any electronic probes or sensors, and am use to tool changes taking place at the home position when the machine starts up. I tried the park positions and run into my limit switches / M6tXX with M6 enabled in general config again run into limit switches / M2XX macros same thing. Is there a way to make a button run an MDI command ? I have also tried tool touching the top of the work piece and from the manual MDI G43 H1etc and no update of tool table.
    I Have been successful so far being able to still use master cam with a default post even though the post for mach3 drew atom smasher tool paths for arcs
    any help in macros or other info would be great
    JB MACHINE LLC
    www.jb-machine.com
    Sep 2005
    287
    Re: UCCNC Help
    Quote Originally Posted by extsuba View Post
    See this thread where I asked a similar question:
    http://www.cnczone.com/forums/showth...o%20attach%20C script to a screen button ??
    The new graphical screen designer allows you to easily add a button. See the instructions in the UCcnc manual.
    Instead of giving the button a number (Identifiers / buttonnumber on the screen editor selection tab), give it your custom macro, e.g. M20000
    In a text editor create your macro code then save it as M20000 or whatever.
    Look in the main UCcnc directory and open the "Documentation" sub-directory for more info on macro functions, etc.
    Keith.
  1. UCcnc CAM
    By vmax549 in forum UCCNC Control Software
    Last Post: 09-16-2016, 04:19 PM
  2. FED UP with UCCNC
    By jcarpenter2 in forum UCCNC Control Software
    Last Post: 03-10-2016, 11:24 PM
  3. UCCNC & UC300
    By camivic in forum UCCNC Control Software
    Last Post: 10-27-2015, 08:45 PM
  4. UCCNC Wizards (;-)
    Last Post: 09-20-2015, 02:35 AM
  5. Has anyone really used UCCNC?
    By greggv in forum UCCNC Control Software
    Last Post: 08-16-2015, 10:45 AM
