585,582 active members*
4,722 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 6M write-enable toggle switch
    Apr 2016
    5
    Hi guys,
    I'm a total newbie and I have been tasked with getting the PC connected to the FANUC 6M controller. The punch code is set to 0, and I need to set it to 1.
    My problem being is I can't locate the write-enable toggle switch on the main motherboard.
    Is anyone able to describe to me where it is, or maybe send a picture of it?
    Many thanks,
    Mike Evans!
    Apr 2009
    1379
    Re: Fanuc 6M write-enable toggle switch
    bottom left on the main/master board.
    Apr 2016
    5
    Many thanks. managed to change the Punch Code.
    No effect, back to the old drawing board!
  1. Reversing an electric drill using a toggle switch
    By kazuo in forum CNC Machine Related Electronics
    Last Post: 12-29-2009, 11:48 PM
  2. Q: Mach3 Wiring / Toggle Switch
    By Deviant in forum Gecko Drives
    Last Post: 02-11-2009, 04:21 AM
