585,975 active members*
4,420 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > Multicam 44 plus Newbie needs help!!! CNC Router suddenly stopped working.
Results 1 to 6 of 6
    Apr 2016
    Hi All.
    This is my first post having just bought my first CNC router. She's old but sturdy. 1997 sort of build date I believe.
    Its a Multicam44plus. High freq spindle, With en route 5 software preinstalled on a tower. Have used it around 10 times whilst learning how to use the machine in general.
    Today we turned it on and all we got from the controllers Lcd was a blinking first character. We normally get some words (cant quite remember what) 'Cipher multicam' etc. Then we can home the machine and send the file over from Enroute5.
    We have opened up the main control box and checked a couple of the tiny fuses (the ones we could see) to no avail.
    Its almost as if the main controller computer bolted to the bed needs a reboot, no matter how many times we turn it on or off it wont boot.
    If anyone has any ideas of what might be wrong we would really appreciate the help.
    Jun 2010
    463
    Re: Multicam 44 plus Newbie needs help!!! CNC Router suddenly stopped working.
    open up the control cabinets....take a picture and post it please
    Apr 2016
    Thanks for your reply. We managed to get the control panel to liven up again, but not for long. We managed to find a second hand board which had a 19200 baud rate with even parity. (i dont know what that means by the way) but I know the one we had was 8700? with even parity. So anyway managed to change the coms setting to match and send the file via en route software as we used to. However the new board obviously had a different version on it as the control unit now asked to fit the tool bit which we had chosen on the pc (eg 5mm end mill) . BUT none of the buttons, or combinations of buttons would allow us to confirm tool change and proceed to cutting.
    Whatever our first issue was, power surge, maybe, has happened again and we now only get the blinking cursor. Is the best bet going to be fitting a newer control unit and aftermarket board?
    Attachment 323212
    Attachment 323214
    Attachment 323216
    Jun 2010
    463
    Where are you located?
    Apr 2016
    UK- southampton area.
    Dec 2011
    Hi, anyone here can help share Multicam 44 plus firmware file?
  1. Multicam feed rate suddenly really slow
    By fender316 in forum Multicam Machines
    Last Post: 08-26-2013, 05:13 PM
  2. Working copy suddenly says it's a Demo
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 07-20-2010, 10:23 PM
  3. Newbie needs help with DNC hookup to Multicam router
    By newlife in forum Commercial CNC Wood Routers
    Last Post: 06-02-2009, 10:07 PM
  4. DSP controller suddenly stopped working, any ideas?
    By dougie329 in forum Excitech routers
    Last Post: 04-26-2009, 01:52 AM
  5. SX3 Stopped Working
    By mikemill in forum Syil Products
    Last Post: 01-09-2009, 04:54 PM
