585,702 active members*
4,085 visitors online*
    Jan 2006
    6
    amada pega 345 fanuc o4-pc
    HI all, I have a weird problem that I can't identify it's source, when I start the machine and press the jog and turret button for zero refrence the auto index turns 360 degree until it shows 0 on the screen then the turret starts to rotate as the turret lamp button starts to blink, once it settles on the home station it writes on the screen 220 but the turret button lamp doesn't go on. it happens 80% of the machine start up it lights up and is ready to work for only 20% of the tries.
    please help as I have just bought this machine.
    Sent from my SM-N910T using Tapatalk
    Jan 2006
    6
    Re: amada pega 345 fanuc o4-pc
    I am sad that I didn't receive any reply.
    but the problem got solved so I would like to share the solution so it might help anyone who might face this headache.
    the problem was that the striker was not getting its actual location in center and so the reference zero was not complete.
    I need the troubleshooting and fault codes of the fanuc 04pc if anyone have it. also I need the procedure for adjusting the offset in the x and y axis.
    Oct 2012
    40
    Hi , are you still need the info?
    Regards,
    Deepak
    +91 9222018538
    [email protected]
  1. Pega 344 Amada Fanuc 6M electrical diagram
    By nguyenthanhthi in forum Fanuc
    Last Post: 02-07-2024, 10:12 AM
  2. Amada pega fanuc 04pc system error
    By cndcnd in forum Fanuc
    Last Post: 10-10-2018, 04:47 PM
  3. amada pega 357 - fanuc 6m
    By stevematt in forum Omni CNC
    Last Post: 04-01-2016, 05:59 AM
  4. Replies: 2
    Last Post: 09-29-2015, 04:02 PM
  5. Replies: 10
    Last Post: 08-10-2011, 10:14 PM
