I currently have the X2 mill with the cnc fusion kit on it. As we all know the X2 Mills Y axis is limited to about 4", without any rubber protectors. I need to do some 4.25 -5" OD diameter work so I purchased the SX2 base from LMS as it offers a longer Y axis and the rest of base are the same specs as the X2 base. So my question is, do I need a longer Y axis ball screw to fit on the longer SX2 base? Or can I add some sort of extension/connection to my current CNCFUSION kit with the shorter Y-axis ball screw? The CNC FUSION kits use 5/8" x .200 pitch ball screws. If I need a larger length Ball screw, what length would I need, and as I do not know much about the Ball nuts , what kind of ball nut would I need on the ball screw? Thank you for any help, as I have this job coming up within 2 weeks and I need to get everything set up and figured out so I can get the job up and running.
