585,962 active members*
3,776 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Replaced SL1H door glass on the cheap
    Apr 2016
    10
    Used 1/4" lexan sheet, jig saw to size
    Replaced rubber gasket, which was both old and hard, and also designed for 4mm thick windows which are really hard to find, with mcmaster p/n 3275T22 one-piece gasket which works similarly but has the locking strip built in instead of as a separate piece of cord
    I picked lexan because its practically bullet proof, but I notice alot of machine tools have acrylic, which from what I can tell is much more brittle and prone to shatter..although I think more scratch resistant
    Feb 2006
    338
    Re: Replaced SL1H door glass on the cheap
    The lexan will chip and wear over time. While it is tough it may or may not be a strong on an actual impact as the original window was.
    Just remember it isn't just a window, but a saftey shield too.
    Apr 2016
    10
    Quote Originally Posted by dpuch View Post
    I'm more concerned with it as a safety shield, thats why I put in lexan in instead of acrylic. Are you saying there is another plastic that would be superior to lexan for impact resistance at this thickness?
    Feb 2006
    338
    The newer machines I have looked at have been putting in 1/8 to 1/2" saftey glass composited with lexan on the operator. Total thickness is 3/4 to 1"
    Granted these are large windows without the metal grid or bars. We have some older machines with only 1/4" thick lexan but that is backed by sheetmetal that only had 4x6" openings cut out in a grid.
    Design trends have changed over the years (usually towards more saftey) and I'm just commenting based on the examples I have seen. Just make sure your not mistakenly replacing a window with something weaker.
    Apr 2016
    10
    As I said in the original post, the window that came with the machine was 4mm thick and I replaced it with 1/4" thick. So the new window is thicker than the original. The new window is also Lexan which is the most impact resistant plastic material available for this thickness.
  1. NLX2500Y DOOR GLASS REPLACEMENT
    By SKENEY in forum Mori Seiki lathes
    Last Post: 04-16-2016, 02:16 AM
  2. Replies: 0
    Last Post: 04-12-2016, 09:19 PM
  3. DRO - Glass scales or cheap Chinese digital scales?
    By strandbygaard in forum Benchtop Machines
    Last Post: 04-05-2010, 03:01 AM
  4. Replies: 40
    Last Post: 02-08-2008, 12:03 AM
  5. good source for cheap glass scales/linear encoders?
    By mbwittig in forum Bridgeport / Hardinge Mills
    Last Post: 10-25-2006, 05:58 AM
