585,573 active members*
3,516 visitors online*
    Apr 2016
    fiber laser suddenly lost engraving power
    Hi all.
    I have a 30w fiber laser (from Laserstar). I am engraving steel and aluminum. The machine was running fine yesterday, then I stepped away and when I came back it was as if suddenly the power was turned almost all the way down. The machine is still tracing the art, but with almost no power.
    - I've experimented with changing various power settings, no luck.
    - I've put the laser on continuous cut mode and played with height from material, and it is not behaving better at any focal length.
    - I've checked the mirrors and lenses and all are in good shape.
    - All cables are plugged in and undamaged
    Anyone have any ideas on what I can try to check next, or what my problem might be?
    Thanks!
    - Jay
    Apr 2016
    Re: fiber laser suddenly lost engraving power
    Just an update in case anyone is searching, and comes across this in the future. Turns out the optic cable had been kinked, but looked ok visually. Sent machine back and Laserstar repaired it.
    Yes, yes, fiber laser yellow cable could not be kinked.
    Web.:http://www.jncslaser.com/ Email: [email protected] Whatspp: +86-18254116182
    Facebook: https://www.facebook.com/jncslaser Skype: consurelaser
  1. 50w laser has lost power & does not appear to firing correctly, do i need a new tube?
    By Devoreg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-12-2016, 03:17 PM
  2. AK10F- A Portable Fiber Laser Marking Machine for Plastic, Fiber and Metal Engineerin
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-29-2016, 05:35 PM
  3. Steppers suddenly lost torque
    By R_garza in forum Stepper Motors / Drives
    Last Post: 08-22-2015, 07:34 PM
  4. Lost in Laser Engraving
    By mojotommy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2012, 02:15 AM
