585,748 active members*
3,407 visitors online*
Page 2 of 3 123
Results 21 to 40 of 46
  1. #21
    Aug 2007
    92
    Re: Extron E320 CNC mill communications.
    I forgot to check back recently, I'm glad there's been some other people post here. I have a Fusion 360 post and a Mastercam one which are very close if not spot on. I've been using sheetcam as most of my work is 2.5D and it's quick and simple from a DXF so I have a post for that as well if anyone needs it.
    Does anyone have DNC set up on their machines? A lot of the F360 code for the 3D work I've been doing goes over the line limit of the control so it might be time to get that sorted out.
    FastFarmer, no legal issues making the stocks. They're not a firearm part as per the definitions in the legislation.
  2. #22
    Jul 2009
    152
    Quote Originally Posted by proengines View Post
    I have DNC on my machine, I will have to check what software I used, I also now have a "Shoplink Flash" it works better than the DNC with it I just plug in a USB and run from it.
  3. #23
    Jul 2016
    8
    Quote Originally Posted by Rick_B View Post
    OOOH, I have DNC working but would be interested in the "Shoplink Flash"
    @Proengines, I have a F360 post but and finding when I tap a thread it seems to come up with an error but when I fix that issue I get an error with feedrate. I can't remember what I have done in the past to work it out but need to fix it again now as I've upgraded my computer and my originally set up post isn't there anymore
  4. #24
    Jul 2009
    152
    Quote Originally Posted by Aly-Tek View Post
    USB reader for CNC's, HAAS-FANUC-for most CNCs, connect to RS232, ShopLink FLASH | eBay
  5. #25
    May 2018
    I would a love a copy of any MIRL 2000 info you have.
    or extron alarm codes etc.....
    Cheers Kyle
  6. #26
    Sep 2013
    6
    Kyle
    Can you give an email address and will share via dropbox.
    Conversational manual and operator's manual are around 20mb each.
  7. #27
    May 2018
    [email protected]
    Thanks in advance
  8. #28
    May 2018
    Any idea why i am getting the alarm MLC 002 TOOL CLAMP/UNCLAMP NOT EXACT
    i have done hundreds of tool changes before and this has just popped up all of a sudden.....
    i can't find a trace of MLC alarms for it anywhere.
    Cheers
  9. #29
    Oct 2004
    178
    Peter, can't you use the chook postupdate ( or something like that) to get your version 9 post to work on MCX?
  10. #30
    Sep 2013
    6
    G'day Greggv, Have got around it by using solidworks and fusion 360 cam, thanks mate
  11. #31
    Sep 2010
    6
    Exclamation Extron using ShopLink
    Greetings, this is Jerry from ShopLink, makers of ShopLink FLASH products.
    I have another user trying to use ShopLink on a Extron with a Mirl 2000 control.
    Did your machine have a 9pin or 25pin connector? did the provided cable work without modification?
    What settings did you have the Extron set to for communications, 7 data bits, even parity, 1 stop bit
    at 9600 baud or other.
    Jerry
  12. #32
    Sep 2010
    6
    Peter35 - I would certainly be interested in the manual. [email protected]
  13. #33
    Nov 2021
    15
    Hi all looking for bit of help ive not long got an extron but cant seem to get titan dnc to run to rs232 if anyones free for a chat ild love to touch base.
  14. #34
    Aug 2007
    92
    Quote Originally Posted by jmweng View Post
    I bought one of the same DNC setups and couldn't get it to run successfully (probably more my skills setting it up than a problem with the Titan setup). I've got my machine set up running networked to my PC with netbeui, it opens the programs directly fron the computer and works perfectly. My issue was that the control has a 10,000 line limit on the programs which got annoying with some longer programs or 3d parts. If you set up your post processor to leave off the line numbers, the machine will run as many lines as you want up to the limit of the memory in the controller. I haven't had any issues with running out of memory to this point. You do lose the ability to "run from" a particular line if you need to restart the program part way through but I haven't had a problem where I needed to do that to this point.
    I'm still running windows XP on the computer it's connected to. Apparently it was the last windows version that will run netbeui easily? I'm not 100% sure of that but I'm not game to try in case I mess something up. It was all a fair while ago now so I couldn't run you through it easily. I can take some screen captures of different settings if you need them though.
  15. #35
    Nov 2021
    15
    Thanks heaps mate ill definitely have to look a
    Into that then. If possible ild love to touch base with you directly if you got time sometime. I still havnt found what post to use yet
  16. #36
    Jul 2009
    152
    I replaced my shoplink, just could never get it to work right I ended up changing it over to a Titan DNC and have never looked back. That was 3yrs ago now and it is still going strong.
  17. #37
    Nov 2021
    15
    What controller??
  18. #38
    Jul 2009
    152
    Fanuc IO-mate -MB it was pretty much plug and play.
  19. #39
    Nov 2021
    15
    Yeh ok im told mine is very simlar to fanuc. Maybe i have some settings wrong but dont seem to know where to head with it or what to do pretty usless to me if i cannt inout a program
  20. #40
    Jul 2009
    152
    OK, what are you doing to load your program? what happens after you try to load your program?
Page 2 of 3 123
  1. HELP, Wiring diagram for Extron/ Hafco BM 90VCNC mill needed.
    By oliomio in forum Knee Vertical Mills
    Last Post: 02-11-2021, 05:56 AM
  2. Fagor 805M parameters lost extron BM90
    By david2259 in forum Fagor Automation
    Last Post: 09-14-2011, 12:31 AM
  3. Communications
    By JOHN PARSONS in forum Want To Buy...Need help!
    Last Post: 07-07-2010, 10:43 PM
  4. communications help
    By goaler in forum Okuma
    Last Post: 01-30-2010, 05:07 PM
  5. Extron Milling Machine Upgrade
    By ferman in forum Controller & Computer Solutions
    Last Post: 10-12-2009, 01:51 AM
