Hi I have a 3 axis wood router running under mach3, Can I use Alibrexpress and Meshcam to make parts such as bridges and necks? If not what do you suggest, I don't have a lot of money to spend, I'm just a poor luthier.
It's possible, if your really good with Alibre. Model and export as .stl, provided your version of Xpress can export an .stl
Ger, I checked my version of xpress and it does export .stl. If I didn't go this route what would you recommend as a low cost alternative? BTW Thanks Ger for all the help you gave me on my machine a year ago.
Ed.
I'd try to find the CAD program that is easiest for YOU to model your parts. Necks can be tricky to model. A lot of guys use Rhino. You could also try TurboCAD and DesignCAD.
