585,568 active members*
3,573 visitors online*
    Jun 2003
    12
    Delta 20 Power Supply
    Hi all:
    Haven't used my Tree 325 in about a year. Went out to turn it on, and the spindle fan went on, but nothing else.
    Did some checking, and found low voltage at the power supply output. Pulled it out, and I figured I would replace all the capacitors. All the date codes were 1989 or 1990.
    Also, I checked around for a new power supply. I think I found one with the correct voltages.
    Does anyone know about the power supply, other than the voltages ? There is some kind of power failure circuit in the power supply. I think it monitors the 5 volt output, and somehow controls the 24 volt output.
    Jim
    Apr 2012
    84
    Re: Delta 20 Power Supply
    Hey Jim,
    We do power supply repairs all the time. Shoot me an email with the part number and info you have and I'll see what my techs say.
    [email protected]
    We fix it all! Give us a call at 855-437-3497.
    Jun 2003
    12
    The power supply was made by Deltron. The Dynapath part number is 4202805. Deltron number is 11180XA, which I think is a Dynapath only number. . It appears to be a V225D04.
    I have found a power supply that should work. The only question is how the power failure circuit works.
    Feb 2016
    115
    Quote Originally Posted by JimP View Post
    Hi all:
    Jim
    I have a power supply for your controller if you need one.
    [email protected]
  1. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  2. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  3. Power Supply/Power Cord Sizing for Four 850 oz-in Servos, One is Slaved
    By Plugger in forum CNC Machine Related Electronics
    Last Post: 03-11-2012, 05:52 AM
  4. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
