Re: G-350 laser cutter: sudden power drop?
Its possible - Laser tubes IMO do not seem to live up to their stated hours. First things to check are that the lens is clean and not cracked. A cracked lens can cause issues (and yet it will still sort of work).
It could be the power supply or the controller and if you have a spare power supply it might be worthwhile to test it by swapping in the new one. The controller can be tested by a multimeter at the power supply - one connection is a full voltage from the power supply and another is the % voltage of power (ie 50% power would have a voltage of 50% of the full voltage line). So that's pretty easy to test once you figure out (laser power off) which line is which.
Another possibility is scratches or dirt on the mirrors - and depending on your cleaning regime - once a day cleaning may be too much if it includes the mirrors. Scratches can cause the beam to lose power on its way to the lens.
So to recap - its usually the tube. But to quickly and easily tell it helps to have a spare power supply. Then you can quickly isolate the controller/power supply/tube when issues occur. I don't have this either but its ideal and I should (we have 2 locations and 2 lasers so that's our alternative back up plan). It also helps to have spare mirrors and lens for maintenance and troubleshooting.
But I think way too often it is the tubes that fail early especially on new machines- though I think 150 hours is low for sure. I swear sometimes its like they price it low because its using factory seconds for things like the tube.
PS - I would not assume a replacement tube is only going to work 150 hours (unless you are over powering it - do you have a milliamp meter on it?) They should last a lot longer than that.
PPS - I think also there are no 50W tubes - there are only 40w tubes that have a max power of 50W (which they advertise even though it will kill the machine fast). What I am not sure about is what those machines use for a power supply. 65% seems low if its a 40W power supply for the cutting you described but if its an 80w power supply it might be too high - this is where the milliamp meter comes in so you can see what the power usage is and compare it to what the tube can take.
In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
