Technical parameters
Model: LF3015C
Laser source: IPG or Raycus
Fiber laser power : 500W, 750W, 1000W (Optional)
X, Y and Z axis stroke : 3025mm, 1525mm, 100mm
Weight : 5500KG
Appearance size : 4800*2600*1750mm
Working size : 3000*1500mm
X and Y positioning accuracy : +-0.05mm
Max speed : 100m/min
Max acceleration : 1G
Max load-bearing of work table : 500KG
Transmission mode : important high precision with double driving rack
Power consumption of whole machine : < 15KW (< 12KW-1 KW)
Rated voltage and frequency : 380V/50Hz/60Hz/60A
Applicable materials
Professional for cutting a variety of sheet metal, has best quality to cut 0.5-6mm carbon steel, 0.5-5mm stainless steel, ( the max cutting thickness is 3mm if you use N2, and 5mm if you use O2) it also could cut galvanized sheet, electrolytic plate, siliciun steel and other metal materials.
any enquiry of laser cutting machine, please cionatct and hope go furhter.
Attachment 317670Attachment 317672Attachment 317674Attachment 317676Attachment 317678Attachment 317680Attachment 317682
Quiven form gweike laser,
skype:wkquiven
[email protected]
