585,762 active members*
4,092 visitors online*
Results 1 to 9 of 9
    VCarve Post Processor for the KRMx01?
    What Post Processor do I select for use in VCarve Pro for the KRMx01?
    Re: VCarve Post Processor for the KRMx01?
    What control software are you using?
    Mach III
    Then you'd use one of the Mach3 post processors.
    Thanks! I'll give her a shot.
    https://www.dropbox.com/s/8akchudzyb...58.55.png?dl=0
    There are a bunch of them. Not sure which to choose. Mach III ARCs Inch? How do I go about determining the correct one? I can upload the project if need be so you can see what I am doing...
    Quote Originally Posted by WV_Kokamo_Joe View Post
    I think I got it. I chose the Mach 2/3 Arcs (Inch) and did a dry run. Looks like that is the one. Thanks for all of the help. This is how we learn!
    If your using inches, and only one tool, then use the arcs-inch.
    if you want to use multiple tools in one g-code file with tool changes, use the arcs-inch ATC post.
    Aug 2010
    686
    Yes, that is the one.
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. KRMx01 Build Log
    By msimpson99 in forum Uncategorised WoodWorking Machines
    Last Post: 01-25-2013, 01:12 AM
  3. What post processor to pick in VCarve for a Rover 20 NC410?
    By gothdesigner in forum CNC Machining Centers
    Last Post: 03-06-2008, 12:20 AM
  4. Replies: 1
    Last Post: 11-15-2007, 01:51 PM
