585,902 active members*
3,977 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Fanuc lathe guy trying to learn Okuma-Please help me
Results 1 to 9 of 9
    Jun 2006
    17
    We just bought a brand new Okuma Genos, 2-axis lathe. Control has Usertask2. I am trying to do a few things.
    First, I cant figure out how to emulate a While/Do loop.
    Ex
    WHILE[#107LT#105] DO1
    #107=[#107+1]
    END1
    Second, How do I perform a Z-axis incremental workshift like this:
    run 1st part
    #5222=[#5222-#120] (#5222 is Fanuc system variable for G54 Z-axis workshift amount)
    run 2nd part....
    #5222={#5222-#120]
    run 3rd part..
    #5222=0.0(reset workshift back to zero before next barpull)
    I have read the manual and it is hard to understand.
    I have also found very little info on the web regarding Usertask2 examples.
    Scott
    Jun 2015
    4154
    Re: Fanuc lathe guy trying to learn Okuma-Please help me
    Hy,
    Here is an example for REPEAT-UNTIL, instead of WHILE-DO ... ok 4 u ?
    V1=100 ( cycles )
    V2=0 ..( increment )
    NHERE
    V2=V2+1
    ( do something )
    IF [ V2 LT V1 ] NHERE ( or ) (
    IF [ V2 LT V1 ] GOTO NHERE )
    LT - lower than <
    LE - lower than or equal <=
    EQ - equal =
    NE - not equal <>
    GT - greater than >
    GE - greater than or equal >=
    Z-axis incremental ... please explain a bit more what d u wish
    i got it
    V1=9999.888 ( length to machine afferent to one cycle / program / part )
    ( program goes here )
    VSZOZ=
    VSZOZ-V1
    VSZOZ=VSZOZ-V1
    Jun 2015
    4154
    now, let's make a cocktail with those two :
    V1=100 ( cycles )
    V3=9999.888 ( length to machine afferent to one cycle / program / part )
    NHERE
    V2=V2+1
    VSZOZ=VSZOZ-V3
    let's avoid Z_origin changing on last part
    NHERE
    V2=V2+1
    IF [ V2 EQ V1 ] NSKIP
    VSZOZ=VSZOZ-V3
    NSKIP
    let's restore initial Z_origin at programs end
    NHERE
    V2=V2+1
    VSZOZ=VSZOZ-V3
    NSKIP
    VSZOZ=345.896fd4gfd654h56gf4 ( u got it ? )
    let's say you wish to cut 10 parts ... so, you will declare V1=10
    let's say you won the lotery, you reset the machine during 5th part, go get happy, and come back to continue ... just declare V2=5-1 instead of 0
    if you are too happy, don't forget on next run to restore V2=0
    kindly !
    Jun 2015
    4154
    final touch :
    V1=100 ( cycles )
    NHERE
    V2=V2+1
    CALL OPROG
    VSZOZ=VSZOZ-V3
    NSKIP
    VSZOZ=... ( constant value )
    OPROG
    RTS
    Jun 2006
    17
    Thank you very much, deadlykitten . Will try this morning and post results
    Jun 2015
    4154
    you ain't got Easter ?
    Jun 2015
    4154
    also photos are welcome
    Jun 2006
    17
    Thank you so much deadlykitten, your suggestions worked great-machine is up and running.
    Had to change VSZOZ to VZSHZ (a workshift, usually at zero).Everything else worked like a charm.
    Fanuc Program:
    O3984
    (DELRIN RING)
    (243AL)
    (P/N SAGE18.6-RI)
    (REV--)
    (4/03/2013)
    (CYCLE-2-14 5PCS)
    (STOCK DIA-.875)
    (**NOTES**)
    (1.SET ALL VARS. BELOW)
    (2.SET STOCK OUT .500 USING STOP-LOC-)
    (-FOR EVERY NEW BAR)
    (3.JOG BARPULLER AND GRAB STOCK)
    (SET BARPULLER X0Z0 HERE)
    (4.MANUALLY SET #550 TO 0.0)
    (5.MANUALLY SET #555 TO 0.0)
    (6.RUN BARPULLER OP.)
    (FACEOFF .01)
    (SET TOOLS)
    (KEEP CHIP CNVYR. OFF)
    (**TOOL LIST**)
    (T0707)(ISCAR .625 DRILL INSERT)
    (ORDER#IDM 0625 GRADE IC908)
    (T0303)(MITSUB INT. PROFILE BAR)
    (T0505)(PICCO R06.7-20 IC228)
    (T0202)(ISCAR 35DEG FR. TURN .004R IC20)
    (T0404)(.031 MAXBAR CUTOFF)
    (T0606)(BARPULLER)
    (COMMON VARIABLES)
    #100=0(LOOP-KEEP AT ZERO)
    #101=5(PARTS PER CYCLE)
    #102=.096(PART OAL)
    #103=.030(CUTOFF WIDTH)
    #104=.003(FACEOFF AMT)
    #105=.043(ID CFER TOOL-FACE TO POINT)
    #106=30.0(BARLENGTH-INCHES)
    (***DO NOT EDIT BELOW THIS LINE***)
    #107=[#102+#103+#104](CYCLE WIDTH)
    #108=[#106-3.0]
    #109=ROUND[#108/[#107*#101]](FEEDS/BAR)
    #110=[#107*#101](BARPULLER FEEDOUT)
    N100(BARPULL)
    M72(CHUCK CLOSE)
    T0606
    G54
    #5222=0.0(W.SHIFT SAFETY)
    G0X3.0Z.5
    Z0.0
    G98G1X0.0F100.0
    M71(CHUCK OPEN)
    G04U1.0
    G1W[#110+.005]F100.0
    M72(CHUCK CLOSE)
    G4U.5
    G1X3.0F100.0
    G99
    G0G28U0W0
    M01
    N200(INITIAL FACEOFF)
    T0202(ISCAR 35 DEG .004R FT IC20)
    G54
    G50S3500
    G96S500M3
    G0X.9Z.5
    Z.002
    G1X.5F.0015
    G0U.05W.012
    G0Z.1
    G0G28U0W0
    M01
    N300(*DRILL THRU*)
    T0707(.614 INSERT DRILL)
    G54
    G97S1800M3
    G0X0Z.25
    Z.05
    G1
    Z-1.0F.009
    G0Z.25
    G28U0W0
    M01
    N400(*BORE*)
    T0303(CCGT 2-0-SM GROIC907)
    G54
    G50S4000
    G96S500M3
    G0X.719Z.1
    Z.05
    M6
    G1
    G74R.005
    G74X.719Z-.730Q500R-.005F.005
    G0X.739
    G04U1.0
    M7
    G1Z-.73F.002
    X.710
    Z-.830
    U-.02W.01
    G0Z.5
    M6
    G04U1.0
    M7
    G28U0W0
    M01
    N500(*INTERNAL CHAMFERS*)
    T0505(PICCO R06.7-20 IC228)
    G54
    G50S4000
    G96S500M3
    G0X.7Z.5
    Z-[#105]
    WHILE[#100LT#101]DO1
    (FRONT CHAMFER)
    G1X.749F.001
    G0X.7
    W-[#107]
    #100=#100+1
    END1
    #100=0.0
    G0X.65
    Z.5
    (BACK CHAMFER)
    X.7Z-[#105]
    W-[#102]
    WHILE[#100LT#101]DO2
    G1X.752F.001
    G0X.7
    W-[#107]
    #100=#100+1
    END2
    #100=0.0
    M6
    G0X.65
    Z.5
    M7
    G28U0W0
    M01
    N600(FACE TURN + CUTOFF*)
    WHILE[#100LT#101]DO3
    T0202(ISCAR 35DEG FR. TURN .004R IC20)
    G54
    G50S3000
    G96S600M3
    G0X.675Z.1
    M6
    Z.02
    G1Z0.0F.001
    M7
    X.7843
    X.809Z-.0123
    Z-.0302
    X.796Z-.0367
    Z-.054
    G2X.818Z-.065R.011
    G1X.8483
    X.859Z-.0703
    Z-.0987
    X.8436Z-.1064
    G0X.9
    Z2.5
    (CUTOFF)
    T0404(MAXBAR .031 CUTOFF)
    G0X.950Z.5
    M6
    Z-[#107]
    M7
    G1X.660F.0015
    G0W.01
    G0X.950
    G0Z2.5
    #5222=[#5222-#107](WORKSHIFT)
    #100=#100+1
    END3
    #5222=0.0(RESET W.OFFSET)
    #100=0.0
    G0G28U0W0
    M05
    #550=#550+#101(PART COUNT)
    #555=#555+1(FEED COUNT)
    IF[#555EQ#109]GOTO1000
    GOTO1500
    N1000
    M71(COLLET OPEN)
    #555=0.0(RESET FEED COUNT)
    #3000=100(CHANGE BAR-HIT RESET)
    N1500
    /M99
    M30
    Converted for Okuma:
    (REC DELRIN RING)
    (243AL)
    (P/N SAGE18.6-RI)
    (REV--)
    (4/03/2013)
    (CYCLE-2-14 5PCS)
    (STOCK DIA-.875)
    (**NOTES**)
    (4.MANUALLY SET V198 TO 0.0)
    (5.MANUALLY SET V199 TO 0.0)
    (FACEOFF .01)
    (SET TOOLS)
    (**TOOL LIST**)
    (T0303)(PICCOR06.7-20IC228)
    (T0404)(ISCAR35DEGFR.TURN.004RIC20)
    (T0505)(MITSUBINT.PROFILEBAR)
    (T0707)(ISCAR.625DRILLINSERT)
    (T0808)(CUTOFF)
    (T1212)(BARPULLER)
    N50
    (COMMON VARIABLES)
    V100=0 (LOOP-KEEP AT ZERO)
    V101=5 (PARTS PER CYCLE)
    V102=.096 (PART OAL)
    V103=.078 (CUTOFF WIDTH)
    V104=.003 (FACEOFF AMT)
    V105=.043 (ID CFER TOOL-FACE TO POINT)
    V106=30.0 (BARLENGTH-INCHES)
    V107=[V102+V103+V104] (CYCLE WIDTH)
    V108=[V106-3.0]
    V109=ROUND[V108/[V107*V101]] (FEEDS/BAR)
    V110=[V107*V101] (BARPULLER FEEDOUT)
    CLEAR
    DRAW
    N100 (BARPULL)
    M72 (CHUCK CLOSE)
    T1212
    VZSHZ=0.0 (W.SHIFT SAFETY)
    G0X3.0Z.5
    Z0.0
    G94G1X0.0F100.0
    M84 (CHUCK OPEN)
    G04F1
    G91
    G1Z=[V110+.005]F100.0
    G90
    M83 (CHUCK CLOSE)
    G04F2
    G1X3.0F100.0
    G95
    G0X20.Z20.0
    M01
    N200 (INITIAL FACEOFF)
    T0404 (ISCAR 35 DEG .004R FT IC20)
    G50S3500
    G96S500M3
    G0X.9Z.5
    Z.002
    G1X.5F.0015
    G0X.55Z.014
    G0Z.1
    G0X20.0Z20.0
    M01
    N300 (*DRILL THRU*)
    T0707 (.614 INSERT DRILL)
    G97S1800M3
    G0X0Z.25
    Z.05
    G1
    Z-1.0F.009
    G0Z.25
    X20.0Z20.0
    M01
    N400 (*BORE*)
    T0505 (MITSUBINT.PROFILEBAR)
    G50S4000
    G96S500M3
    G0X.719Z.1
    Z.05
    (M6)
    G1
    G74X.719Z-.730D500DA=.005F.005
    G0X.739
    G04F1
    (M7)
    G1Z-.73F.002
    X.710
    Z-.830
    X.69Z-.82
    G0Z.5
    (M6)
    G04F1
    (M7)
    G0X20.0Z20.0
    M01
    N500 (*INTERNAL CHAMFERS*)
    T0303 (PICCO R06.7-20 IC228)
    G50S4000
    G96S500M3
    G0X.7Z.5
    Z=-[V105]
    N525
    IF [V100 GE V101]GOTO N550
    (FRONT CHAMFER)
    G1X.749F.001
    G0X.7
    G91
    Z=-[V107]
    G90
    V100=[V100+1]
    GOTO N525
    N550
    V100=0.0
    G0X.65
    Z.5
    (BACK CHAMFER)
    X.7Z=-[V105]
    G91
    Z=-[V102]
    G90
    N575
    IF [V100 GE V101] GOTO N585
    G1X.752F.001
    G0X.7
    G91
    Z=-[V107]
    G90
    V100=[V100+1]
    GOTO N575
    N585
    V100=0.0
    (M6)
    G0X.65
    Z.5
    (M7)
    G0X20.0Z20.0
    M01
    N600 (FACE TURN + CUTOFF*)
    N625
    IF [V100 GE V101] GOTO N650
    T0404 (ISCAR 35DEG FR. TURN .004R IC20)
    G50S3000
    G96S600M3
    G0X.675Z.1
    (M6)
    Z.02
    G1Z0.0F.001
    (M7)
    X.7843
    X.809Z-.0123
    Z-.0302
    X.796Z-.0367
    Z-.054
    G2X.818Z-.065L.011
    G1X.8483
    X.859Z-.0703
    Z-.0987
    X.8436Z-.1064
    G0X.9
    Z2.5
    G0X20.0Z20.0
    (CUTOFF)
    M77(PARTS CATCHER ADVACE)
    T0808 (MAXBAR .031 CUTOFF)
    G0X.950Z.5
    (M6)
    Z=-[V107]
    (M7)
    G1X.660F.0015
    G0Z.01
    G0X.950
    G0Z2.5
    VZSHZ=[VZSHZ-V107] (WORKSHIFT)
    V100=V100+1
    GOTO N625
    N650
    VZSHZ=0.0 (RESET W.OFFSET)
    V100=0.0
    G0X20.0Z20.0
    M76(PARTS CATCHER RETRACT)
    M05
    V198=[V198+V101] (PART COUNT)
    V199=[V199+1] (FEED COUNT)
    IF [V199 GE V109] GOTO N1000
    GOTO N1500
    N1000(BAREND SEQUENCE)
    M84 (COLLET OPEN)
    V199=0.0 (RESET FEED COUNT)
    VUACM[1]='REPLACE BAR'
    MSG (REPLACE BARSTOCK)
    VDOUT[992]=1
    N1500
    /GOTO N50
    M30
    Jun 2015
    4154
    okey dokey
    that code is long and nasty ... if it works, keep it
    i don't have the patience to understand it, but if you wish for an opinion, just post your part
  1. Replies: 1
    Last Post: 11-01-2022, 11:56 AM
  2. Okuma Lathe Fanuc parameter list
    By pacific51 in forum Okuma
    Last Post: 06-11-2015, 04:02 PM
  3. Okuma lathe with fanuc control Z alarms
    By rob jerico in forum Fanuc
    Last Post: 07-18-2013, 06:22 PM
  4. okuma LNC-8 cadet lathe with fanuc control
    By rob jerico in forum Okuma
    Last Post: 02-16-2012, 07:45 PM
