585,973 active members*
4,213 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Waveform programming!
    Apr 2016
    Hi all!, I want to use the waveform programming in surfcam 2016, but don't find this option in roughing o pocket roughing or contour.
    Does any one has idea how to do it??
    May 2014
    11
    Re: Waveform programming!
    Do you know the level of software you have? Waveform is included in Standard milling or higher. It is not in Essential milling.
    May 2013
    142
    Looks like it's time to make a subforum to separate Surfcam and Traditional Surfcam.
    Tradition Surfcam has a waveform style pocketing routine called Pocket Rough. It works great on pockets that are round. Any other shape it loses its advantage because it uses your plunge feedrate as the feed between rate.
    May 2007
    71
    Quote Originally Posted by Billetgrip View Post
    SURFCAM Traditional 2017R1
    The WaveForm 3 Axis ... Look like better than TrueMill 2 or 3 Axis for the Outside Tool Path
    https://1drv.ms/v/s!ArRUdqz-brnsga1M2k6aSczqD5KiZw
  1. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
  2. waveform on a nikken cnc260
    By mdp_72 in forum Linear and Rotary Motion
    Last Post: 11-14-2012, 12:31 PM
  3. High side MOSFET gatedrive waveform question.
    By H.O in forum CNC Machine Related Electronics
    Last Post: 02-19-2010, 01:21 PM
  4. how do I get a good waveform on my laptop
    By cob in forum Machines running Mach Software
    Last Post: 05-17-2008, 05:19 PM
  5. TL2.... programming
    By LorenzoNH in forum Haas Lathes
    Last Post: 04-13-2008, 06:54 PM
