585,575 active members*
3,627 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > nesting 8,13,16mm trespa ( solid grade laminate) router bits tip keep breakkng
    can anyone recommend a cutter we have been using pcb turbo 4flute 16mm cutter 20mm shaft diamond tips router bits, but they keep breaking off.We are running
    them at 20000rpm and 18mpm.thanks
    Re: nesting 8,13,16mm trespa ( solid grade laminate) router bits tip keep breakkng
    What depth of cut are you running at? Trespa is hard, and I've never cut it that fast, and not very often.
    Maybe an Onsrud 68-200 series? I have one, but have never used it.
    Apr 2009
    5516
    I think the PCD as configured may shatter at high speeds... you'd have to check if your parameters put you within the recommended max SFM for the tool.
    Check out Onsrud 67-225 which is PCD with a progressive chipbreaker geometry, 3 flute.
    We have een running at 18000rpm and 13mpermin 3 passes with strict cutters now touch wood they are working will find out in coming b week 200 sheets of trespa and arpa to cut
    Apr 2015
    where you able to find a bit that lasted long and cut well for trespa?
  1. Replies: 0
    Last Post: 08-31-2014, 06:38 PM
  2. Replies: 0
    Last Post: 08-31-2014, 02:19 AM
  3. 3 Flute Solid Carbide Router Bits
    By CDTooling in forum News Announcements
    Last Post: 09-06-2010, 01:19 PM
  4. 4 Flute Solid Carbide Router Bits
    Last Post: 09-06-2010, 01:12 PM
  5. solid Laminate
    By jaywhy71 in forum WoodWorking Topics
    Last Post: 10-11-2007, 12:24 AM
