586,024 active members*
3,681 visitors online*
    Nov 2015
    29
    DIY: Actuated chuck/collet for lathe
    Hi all,
    I've spent several hours now looking for a simple affordable off-the-shelf solution for an actuated chuck/collet that can be opened/closed, e.g. via an Arduino (air-powered?), to be used on a lathe-like contraption (actually, a carbon fiber winder). The jaws (3-4) would need to have a range to accommodate parts between 1/4" and 1/2". The parts I will spin are lightweight (plastic, an ounce max), so no need for heavy duty/high precision/high end materials. I have a Sherline with a turntable, so I can make simple adapters if needed. If I had a good design in front of me, I could even settle for a 3D printed part (I have a makerbot).
    Thank you in advance!
    Feb 2016
    381
    Re: DIY: Actuated chuck/collet for lathe
    Best of luck a simple design for an actuated collet is 90% of an auto tool changer that everyone would be using, might be easier to search for rocking horse poo! I did see someone posted a diy ATC the other day link below
    http://www.cnczone.com/forums/diy-cn...ml#post1875114
    Nov 2015
    29
    Quote Originally Posted by Louis_Cannell View Post
    I would have no problem desinging and making a tool picker (some rails, belts, step motors... no rocket science), but a rotary collet is beyond me since it cannot be put together from simple modules, and has to be balanced.
    I found this on aliexpress for $400. Not cheap, but might be acceptable. Thing is, it's an overkill for what I want to do:
    Standard Two and Four Jaw air pressure Pneumatic Chuck, Lathe Machine Chuck-in Chuck from Industry & Business on Aliexpress.com | Alibaba Group
    Then there is this for $60, but it's probably a misleading title
    KM pneumatic / hydraulic cnc lathe chuck 3 jaw-in Chuck from Industry & Business on Aliexpress.com | Alibaba Group
    Feb 2016
    381
    Yes the tool pickers quite simple the actuated collet is the problem preventing diy or reasonable priced quality ATC.
  1. Mini Lathe Collet chuck
    By cmala in forum Mini Lathe
    Last Post: 10-23-2012, 02:54 PM
  2. Help! Need small CNC lathe with collet chuck
    By Ed Rat in forum Want To Buy...Need help!
    Last Post: 01-25-2011, 12:25 AM
  3. Online ordering power chuck, collet chuck, MC vises form Taiwan
    By mtadirect in forum News Announcements
    Last Post: 08-30-2009, 03:37 AM
