Originally Posted by
brfgmike
Try to do this
Select MDI, turn the memory protect key to off position, hit the command button, look at page number , hit the next page to be on the page 2.
type the command : S key than 500 and input.
you should see that the control display 500 next to S position.
click M-key than type 03 and input.
make sure the chuck is in closed position even if it doesn't hold any material.
Press Cycle Start if all is clear !
You may need to turn the memory protect key back ON, to have a Cycle Start working.
This is the only way my Mori SL-3 executes MDI commands.
Good luck
