I have been looking and researching this site for a whilenow and I think I have a good idea on what I would like to build.
I am in the planning process of build a stationary gantrymilling table.
I would like to use all ½” or ¾” steel plates weldedtogether, but lately I am leaning toward the aluminum after looking at KatranCNC (thank you Katran for the build thread and inspiration)
The minimum work envelopthat I would like to get is 24” X 24” X 12” (X, Y, Z)
Ball screws 2505 -5 with double ball nuts fromlinearmotionbearings2008 from EBay.
HIWIN linear guides HGR25 with HGH25CA carriages
Hertz spindle HMB42 (2.2 KW, 3.0HP, 18000 RPM)
NEMA 23 590 for X, Y & Z
Later on I will be building a 4th axis rotaryfixture with a 6” or 8” lathe chuck (that’s the reasonfor the long Z axis)
I need it to be ridged to cut aluminum at a reasonable depthper cut and maybe light cuts in steel.
What do you guys think is it possible or am I just wastingtime?
What should be changed and what is acceptable?
