Hey everyone,
I've done a lot of research on CNC machines here and have learned quite a bit, so many thanks for all the public information available. Very cool.
Last year, I bought a Chinese CNC machine for a little business venture I was working on. The listing I purchased from is no longer available (how convenient) but this is basically the same one I bought:
3 Axis CNC Router ENGRAVER Milling Machine Engraving Drilling 3040T Desktop | eBay
I have the same bogus blue box. It took a while to get the machine dialed in, and when it works properly, it does a great job. However, since the beginning, I've had stalling issues with the motors. I contacted the seller, they said it was normal, blah blah blah. They sent out a replacement motor and a replacement spindle, because the spindle wouldn't maintain a consistent speed. (I had to rewire the speed potentiometer with wire that wasn't 3 strands)
The original issue was with the z-axis motor. After messing with the motor tuning settings in Mach3, the z- and y-axes operate fast enough with no stalling. I think I had the y-axis running at around 1800mm/min. The z-axis was closer to 500-600mm/min, something like that. I kept having problems with the x-axis motor, so I swapped it out with the new motor the Chinese sent. It wasn't much better, so I started getting it dialed in as best I could. I thought I had it dialed in with the right speed and acceleration, very similar to the y-axis. But then suddenly it started stalling. So I lowered the acceleration and speed, which fixed the issue up until couple of days ago. I started getting a few stalls here and there, and then today when I was working on a project, I had major stall issues. I lowered the speed down to 400mm/min and acceleration to something like 10, and it STILL STALLS! I've seen videos of stepper motor machines hauling butt with no issues so I know it's possible and probably normal for the motors to go much faster than mine are, with no issues.
From my research, I've gleaned that it could be the power supply from the blue box. Or the motors are just garbage. Likely both. I removed the snap-in connectors from the motors to the parallel cable and soldered those connections because I thought the snap-in connection could be shaky. Didn't fix the issue.
I'm extremely frustrated with this machine, because for however long we've had it (October 2015) we've never been able to trust the machine. I run jobs on the machine and have to sit there and watch and make sure it doesn't stall. I'm not opposed to watching just to make sure nothing crazy happens, but I'm always holding my breath just waiting for the motors to stall, which happens way to often.
Is the fix here a better power supply/controller box? Are the motors junk? I would give you guys details about the motors, but the eBay listing that I originally purchased from had nothing like what the listing I linked to has. And even that listing doesn't give much detail about the steppers.
Any help you guys can offer is very much appreciated!!
