CO2 laser cutter for sale with high precision
STJ1390 co2 laser cutter could engrave and cut non-metal,such as Acrylic,wood(balsawood,paulownia),double-color board,ABS board,rubber,plastic,glass and so on.
STJ1390 co2 laser cutter with 150W laser tube could also cut some metal,such as,stainless steel,carbon steel.
Features of co2 laser cutter :
1. The linear guide ensures the precise processing effect, which can make delicate and complicated designs on acrylic, wood and PVC and so on for the advertisement, handicraft industries etc.
2. Our three unique protection functions, i.e. anti-interference function, water-protective function and power cut off function ensure longer working life,
safety and effectiveness.
3. Adopting the strip shape platform, which can bear heavier materials such as organic glass, wood and so on.
4. Original Singapore imported lens with molybdenum base, making the equipment produce smaller facula and stronger cutting force, greatly improving working efficiency and reducing cost.
5. Exhausting, absorbing and assistant blowing systems solve the problem that troubles the laser equipments manufacturing industry for years, extending the life of the laser tube.
6. This machine uses USB port to transmit data, equipped with large-capacity internal memory, improving working speed and efficiency greatly.
7. When the laser tube>=100W, Advanced water chiller for cooling laser tube,Adjust temperature automatically. Besides, it has the function that protect the laser tube from damaging caused by any incidents.
8.The laser can also choose CCD camera to improve the working efficiency.
Technical parameters of co2 laser cutter :
NO. |
Model |
STJ1390 |
1 |
Laser medium |
CO2 |
2 |
Working area |
1300*900mm |
3 |
Working table |
Blade table |
4 |
Laser power |
80W/100W/130W/150W |
5 |
Power Supply |
220V/50Hz, 110V/60Hz |
6 |
Min line width |
≤0.15mm |
7 |
Positon accuracy |
0.01mm |
8 |
Repetition accuracy |
0.02mm |
9 |
Cutting speed |
150mm/s |
10 |
Guide rail |
from Taiwan |
11 |
Transmission method |
Shanghai Fulong Belt Transmission |
12 |
Drive system |
Leadshine driving system and stepper motor |
13 |
Cooling system |
water chiller: CW3000 |
14 |
Control system |
DSP off-line |
15 |
Control software |
Coreldraw, Photoshop, AutoCAD, Tajima |
16 |
Graphic format support |
PLT,DXF,BMP,JPG,AI,etc |
17 |
Working environment |
0-45℃, |
18 |
Operating Humidity |
5-95% |
19 |
Net weight |
200 kg |
20 |
Gross weight |
260 kg |
21 |
Option |
Rotary,up-down table,auto focus,honeycomb table |
Samples of co2 laser cutter:
Every co2 laser cutter is packed with great care and tough material.
1. It packed with cling films first and then film bags.
2. It is packed with wooden case which is reinforced with the iron bar on the top and bottom.
With this kind of package, all our laser machine can protect well during long trip by sea or by train.
Warranty of co2 laser cutter :
1. The whole machine: one year
2. Laser tube
40w for 5 months
60w for 6 months
RECI 80W, 100W,130W,150W for 10 months (this is what laser tube supplier offer to us)
3. Laser lens and mirrors: for one month
If the accessories are broken because of quality problems during warranty time, we will change it by free.
4. 24 hour technical support online like skype/whatsapp/remote, you can calling us if urgent.
5. We offer free training in our factory, and our engineers available to service machinery overseas, but the round-trip air tickets, hotel and meals for the engineers should be paid by our buyer.
STYLECNC is a guaranteed manufacturer for CNC Router, Laser Cutter, Laser Marker, Laser Engraver, Wood Lathe and Plasma Cutter. Official website: https://www.stylecnc.com/
