585,996 active members*
4,923 visitors online*
    May 2010
    41
    X & Y edge finding script
    Does anyone have the scripts for X & Y edge finder? I have finally gotten around to modifying an electronic edge finder to work as an probe input.
    I have looked everywhere and have only found the center finding script. Unfortunately, I don't know enough coding to modify it from there.
    Just need probing from LEFT to RIGHT, and from FRONT to BACK (positive direction)
    KL-4530 CNC, KL-6060, 5 3D printers, CNC Fusion Converted LMS Milling Machine, 60w Laser Cutter
    May 2010
    41
    Re: X & Y edge finding script
    It's hard to believe that nobody knows any of these scripts. It's a pretty big part of Mach3 I would think. Anyway I have been searching for three days straight on this subject and have finally landed on a working screenset that uses the original Mach3 screen.
    The button scripts are beautifully annotated too.
    The first sticky post in this forum has some in it.
    http://www.cnczone.com/forums/mach-w...-software.html
    Dec 2009
    166
    Hi have a look at my routines "Squirrel Probes" I just this moment updated all the files
    it uses the original screen set and has all the probes you will ever need.
    Crawling contour
    X Pipe
    Y Pipe
    circles i.d o.d
    Rectangles Id Od
    Singles lines
    and now with 4th Axis with A axis aligned to either X or Y axis
    Quote Originally Posted by squirrel_41 View Post
    Crawling contour
    X Pipe
    Y Pipe
    circles i.d o.d
    Rectangles Id Od
    Singles lines
  1. edge finding script PLEASE HELP
    By dazza73 in forum Mach Software (ArtSoft software)
    Last Post: 05-07-2016, 07:09 PM
  2. X,Y & Z Edge Finding Prob
    By Jigantor in forum MetalWork Discussion
    Last Post: 05-13-2013, 01:56 AM
  3. Edge Finding Conundrum
    By Russ Kaiser in forum Uncategorised MetalWorking Machines
    Last Post: 07-25-2012, 12:20 AM
  4. cnc - is edge finding done manually?
    By Numb Nut in forum Benchtop Machines
    Last Post: 11-09-2008, 10:00 PM
  5. Edge finding a vertical bar?
    By CraigH62 in forum MetalWork Discussion
    Last Post: 01-08-2007, 01:37 PM
