Originally Posted by
tonyrize
I have an HPR130 plasma table, it is controlled by a Multicam CNC, it was bought in 2004. The machine is working great, but the PC fried out, we had another PC we were using on it a long time ago and thought it was a working backup, but it does not allow the plasma head to lower.
Using the handset I can manually control it to tell it to cut a 1" circle and it works perfect, the head drops and makes the cut, but cnc jobs dont lower the head, they only "dry-run".
The PC is running Jobserver, and we only use the Hotwatch function, we drop the cnc files in a folder, and go to the handset to select the job, it previews on the PC screen, and we execute it. Now the job says executing on the handset, the head moves all over doing the job, but it never lowers, it stays a foot off the table. The machinist that set it all up is no longer with us, and we just follow procedure, no advanced knowledge of the machine....
Multicam said they could not help us because "they do not *know how* to use Jobserver 3.9, we have to buy the new version" - which is a bunch of bs, because it looks like everything is functional, just a setting needs to be changed??
Can anyone give me any tips on what to check to make it cut??
