585,759 active members*
4,238 visitors online*
IndustryArena Forum > Machinery Manual, Brochure / Photo Archives > Member / Shop Photos > Trumpf .50 + cutting [ AL, MS, SS, CR ] Edge Performance
    Sep 2015
    Having trouble cutting thick material (.375 - .50 )
    Set up - trumpf 3030
    SS .50-We cut it at 80% 120ipm, high focus point , normal gas and we get hard ragged edges not long but dense.been on the job 8 months, can't get it. Is it even possible with this model?
    Dec 2015
    21
    Re: Trumpf .50 + cutting [ AL, MS, SS, CR ] Edge Performance
    Hi, I recently bought a Trumpf L4003e laser and have yet to see it run. I had 3 different techs hose me and need to get it up and running. Your 3030 is similar I believe and was hoping you could help me fire this up. My issue is that the feed hold keeps coming up, and the pallet changer wont refrence, A OR B pallet. X,Y,Z all will refrence but not W (pallet). I'm not incompetent, just new to this. Reaally need someone with similar machine to help me start cutting, Thank you, Dean. My e mail is [email protected].
    Sep 2015
    Quote Originally Posted by deandmt View Post
    Hi deandmt,
    We'll I'm no pro, however I do have some suggestions, make sure the light barrier is not being blocked and the lasers are aligned, if you can refrence one table and not the other I would look closely at what program your running and the tech table. Also if you hit menu "1151" it will bring up the load unit, make sure your settings are correct, if your changing pallet manually you want it set to 1 or 5 for automatic. Hope this helps.
    Calvin
    Dec 2015
    21
    i'll try it, thank you, Dean, let you know tomorrow.
    Dec 2015
    21
    Hi, i don't have the light barrier hooked up, so we need to avoid that area, it has never been hooked up by me, do i need to hook it up? the techs said not to but they also didn't get me up and running for 20,000. So what next? Dean
  1. New to Trumpf 1005 laser cutting
    By dinick in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-28-2020, 05:04 PM
  2. How to optimize the performance of a plasma cutting machine?
    By aaronhernandez in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 12-30-2015, 12:16 PM
  3. problems on Trumpf laser cutting machine
    By arnoldino in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-03-2015, 04:17 PM
  4. Redsail M900 Cutting Performance
    By REDSAILER in forum Redsail Laser
    Last Post: 08-06-2012, 01:05 AM
  5. High Performance Cutting
    By kalmah in forum MetalWork Discussion
    Last Post: 06-01-2006, 02:36 PM
