Agate forming machine
Main Parameters:
Voltage: AC380V/220V
Power: 750W
Frequency: 60Hz
Rotation speed:2880r/min
Dimension:600*480*1060mm
Weight: 85kg
Function: the stepless speed agate forming machine can adjust workholder speed to achieve high precision processing.
Adapt speed regulation motor in stable speed and huge power. Suit for processing the agate, crystal, gem, shell, etc.
Features:
1. The processing speed is adjustable in working condition for high molding rate.
2. Adapt molding grind wheel,to process any rotator shape,such as round, drop, triangle, calabash, etc.
3. Fit for the round bead, rice bead, fitness ball, ring, bracelet, chess, jade pillow, and other thousand of specs.
4. Suitable for the spiral shape.
5. High efficiency, process about 3000pieces/8hrs.
6. The forming wheel is customed for different emery.
www.dongtai168.com www.dongtai1688.com
gem processing machine
