584,850 active members*
4,390 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > my stepper motor NEMA 23 do not move but make a little noise
    May 2016
    Smile my stepper motor NEMA 23 do not move but make a little noise
    Hello everybody
    My project is a large 3D printer. I understand the CNC zone is about CNC (logic ), but the electronics and motors are very similar between my 3D printer and a CNC (I need powerful motors).
    ELECTRONICS
    ARDUINO Mega 2560 + RAMPS 1.4 + power supply 12V
    DM 5042 external driver + Power supply 36V + NEMA 23 stepper motor
    SOFTWARE
    Repetier Host to communicate with the Ramps
    ARDUINO to upload the firmware (Marlin)
    TROUBLE
    the motor NEMA 23 reacts when the ARDUINO board receives a command … but not as expected : indeed, it makes a little noise like a "zzzzzzzzzzzzzzzzzzz" instead of moving normally (in other words, the axis of the motor does not turn on itself).
    I checked several times the connections, components …etc. It seems to be fine.
    I do not understand where the trouble comes from.
    Anyone can help me ?
    Thank you very much in advance
    best regards
    Fab
    Mar 2016
    322
    Re: my stepper motor NEMA 23 do not move but make a little noise
    if motor acts like this it ususally means that You ar using to high frequency and motor doesn't have time to execute the steps.
    May 2005
    1397
    What steryd said.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. how to make the NEMA 17 4 wire bipolar stepper motor working?
    By emilylee in forum Musical Instrument Design and Construction
    Last Post: 05-11-2016, 09:32 PM
  2. Nema 17 stepper can't make it's move
    By RobotMakerTR in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-28-2016, 06:44 PM
  3. Stepper motor upgrade NEMA 34 or NEMA 42?
    By rogerfries in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2015, 04:59 AM
  4. How to you make a stepper motor move?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 08-24-2010, 06:45 AM
