585,987 active members*
4,436 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > doosan puma 2600 manual tool touchoff
Results 1 to 7 of 7
    Mar 2009
    6
    I am new to doosan lathes with fanuc i series control.
    When I touch a tool on the Dia of the part for the X axis the control does not ask to enter the
    dia of the stock.
    I have never seen this before, how do I enter the X offset for each tool?
    Veets
    May 2016
    30
    Re: doosan puma 2600 manual tool touchoff
    Plenty off stuff on you tube, try this link
    https://www.youtube.com/watch?v=ZYSu7_WZxg0
    Jul 2005
    380
    You don't.
    You set the tool with the setter and it will know where the tool is, you do not need to specify a diameter.
    -Doug
    Feb 2017
    hi,
    i need some help on turning machine puma 2600l. since my company buy this machine in used condition, it came without manual instruction. can someone help me to provide the manual book or pdf? really appreciate your help
    Feb 2013
    788
    Instruction manuals are available through your local Doosan Dealer as a purchasable part.
    To get the specific manual for your machine, you would need to give the local dealer the machine's serial number
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Nov 2013
    65
    I typically use the tool setter but when that isn't an option I use the measure function. Call the tool to be touched off in MDI (G54 T0101) to make that tool offset active. Then touch the tool to a known diameter, for example if the know diameter is 2", select geometry offset by highlighting the X geometry offset for tool number 1, then type in X2. Then hit the measure soft key, that will set the geometry X of tool 1, at this point the X absolute position for tool 1 should read 2.0000. I hope that makes sense?
    Brent
    Jul 2005
    380
    It does.
    OK,
    Activate the tool offset desired - ie T0101
    Touch the tool to the part OD
    Type "X" and the OD - say 2."
    Press "Meas"
  1. I need doosan puma 300 lathe manual!!!
    By wgpiao in forum Daewoo/Doosan
    Last Post: 02-26-2024, 09:04 AM
  2. Replies: 7
    Last Post: 11-04-2019, 02:20 AM
  3. Doosan 2600 lm c axis
    By mattlynx in forum Daewoo/Doosan
    Last Post: 08-04-2015, 09:16 PM
  4. Puma 2600 w/31i control and LNS Sprint 565
    By GreggC in forum Daewoo/Doosan
    Last Post: 01-12-2014, 04:34 PM
  5. Replies: 3
    Last Post: 08-08-2013, 03:11 AM
