585,722 active members*
4,039 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Re: best affordable 3d scanner
    On the off chance that you are searching for a moderate, exact, stationary 3D scanner, there are couple of items which rival the Matter and Form MFS1V1 3D Scanner. Try not to let the cost of under $575 trick you. This gadget is an unbelievable expansion to b3any producer's carport, or can likewise be the ideal fit for outline studios and little organizations which required the examining of littler items. You absolutely can't filter a SUV with this gadget, yet with the capacity to catch an amazing 2,000 focuses every second and sweep at resolutions of around 0.43mm, this scanner will stand its ground against whatever other stationary gadget available. Moreover it can crease up, crumpling to a size of only 3.5 x 8.35 x 13.5 inches, which consolidated with a weight of just shy of 7 pounds makes it staggeringly versatile. High determination outputs will take around 5 minutes and once a model is checked, the product considers the client to fare it as a watertight 3D printable record easily.
  2. #22
    Jul 2017
    22
    3D scanners are the most important part of the 3D printing ecosystem. There are many 3D scanners available on the market, from desktop 3D scanners to handheld 3D scanners and advanced metrology systems, it can have range between $200 to 500
Page 2 of 2 12
  1. Anyone using USB Scanner/Camera with PathPilot (Scanner Function)?
    By ehpepper in forum Tormach PathPilot™
    Last Post: 04-27-2016, 09:01 PM
  2. Galvanometer Scanner/ Galvo Scanner
    By grace cao in forum Laser Hardware
    Last Post: 11-28-2013, 06:52 AM
  3. Affordable VMM
    By Leha_Blin in forum Calibration / Measurement
    Last Post: 02-18-2009, 04:25 PM
  4. Is there Affordable CAD/CAM ?
    By Willyb in forum Tormach Personal CNC Mill
    Last Post: 10-14-2007, 07:51 AM
  5. affordable wet saw?
    By darth442 in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 07-24-2005, 06:39 PM
