I wish to improve the lighting on my CNC machine, Would it be possible to connect both thhe fan and a 24v 5m led strip to 24v fan terminal. LED strip is 48W total 2 AMP Max.
Many thanks in advance.
If you are talking about the 24v fan voltage on a HobbyCNC board, then NO WAY! 2 amps is a helluva lot. That output is only to drive a small fan at a few tenths of an amp.
WoodWorkerB
HobbyCNC.com, WoodWorkerB.com
Thanks for the advice
bigz- empty your private mesage folder!!
all good over here. glad u didnt get flattened!
got a few new machines and having fun!
swapped to uccnc software to run everything now- much better than mach3.
if your on facebook- join my group
cnc machines and parts uk
are you still in the place with old biesse machines?
still doing hobby stuff?
so much to learn, so much to pass on.
