585,969 active members*
4,602 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > How much suffering can u have?
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Feb 2016
    381
    Re: How much suffering can u have?
    I don't know these machines at all just the file format is an old standard format it should be a text file so copy to avoid corruption and open with notepad it may give you the timing information you require to check your exhisting settings.
  2. #22
    May 2016
    32
    I really don't know....the software is older than my machine so it has to work u think
    Verstuurd vanaf mijn SM-G920F met Tapatalk
  3. #23
    35538
    That doesn't look familiar to me with the CN10 control that I used to use.
    All the files that we used to run were created with CadCode.
  4. #24
    May 2016
    32
    I was just thinking that maybe it looks like 1 file butt iff u open it visual there are more libraries
  5. #25
    May 2016
    32
    What does cad code cost?
  6. #26
    35538
    Probably in the $5K and up range. The version I used was from 1997. We were one of their first customers.
  7. #27
    May 2016
    32
    I'll stick to the 100 euro cambam for a while I think
  8. #28
    Feb 2016
    381
    The .tlf file is probably just for information to extract the parameters you need to create your post from a readable text file, all the tlf files I remember from older systems were well documented and quite easy to read, load a sample from the .tlf file the first 20 lines or so and may be able to offer more advice. Simply load into notepad and copy paste first page on screen.
  9. #29
    May 2016
    32
    Figured it out. It's a file containing tool tables part programs and all u need. Pretty software by the way . Think there doing the same now with dxf files.
  10. #30
    Feb 2016
    381
    .TLF is old school when everything was meant to be easily understood, now its often about showing how clever you can be (introducing bugs and errors that no one can find because software is written to promote programmers skills rather than perform tasks well and be easily maintainable).
  11. #31
    May 2016
    32
    Jupz and about protecting every bit of your machine. Customers or not if you want support by a new one
  12. #32
    I have a copy of the master system software for a cn7. does anyone know how to make a iso file in this software?
    thanks
Page 2 of 2 12
  1. News Flash! cnczone suffering it's thrid straight day of spam
    By snowyskiesau in forum News Announcements
    Last Post: 01-22-2016, 01:31 PM
  2. Suffering from RSI. Anyone used a tablet with 3D modeller?
    By Lafaso870 in forum Uncategorised CAD Discussion
    Last Post: 11-06-2010, 08:30 AM
