585,749 active members*
3,660 visitors online*
    Jul 2006
    Z Axix Keeps Running
    I've just finished my router, doing initial setup using TCNC 4.1 with a SOC MC433 controller (latest issue) and NEMA 23 125oz steppers. My problem is that X and Y axis work great but Z axis keeps going for awhile after key release in jog mode, unless I set velocities way down to barely moving. Any ideas?
    Mar 2007
    4
    Post Controller Version Number?
    Hey comptrmedic,
    You say that you have the latest version of the MC433 controller, what is the version number? Im trying to find some one with a version number greater then 1.1B.
    Did you get any of the firmware updates for your controller?
    I ask all this because Im trying to trouble shoot some holding torque issues im having with my card. As soon as I stop sending the PWM to the controller the motors drop completely dead.
    Tyler
    Jul 2006
    Tyler,
    My controller is marked MC433(G), I have a similar problem in that if I power up the stepper power supply with the parallel port connected to the controller the PS fuse blows. As long as I do the PS first then connect the PPort cable then all is fine. I have a sneaking suspicion that it's a grounding issue between the stepper PS and the computer. I haven't tried to track that one just yet, I'm still trying to figure out why my steppers are missing steps if I try to drive the system fast enough not to burn the wood I'm routing. If I run the system at a slow speed all works fine except the wood burns and eventually gets hot enough to set sawdust on fire.
    Jerry
    Mar 2007
    4
    Hardware Setup?
    Hey Jerry,
    I have a couple of question regarding your hardware setup before I can see if I have any recommendations:
    • What are you using to power your motors?
    • How are you fusing your system (are you using a mainline fuse, then a fuse on each motor?).
    • Are you using fast blow or slow blow fuses?
    On my setup I haven't tied the ground from my MC433 board power to my motor ps are I have no issues with that. I'll post a picture of my control box later this week.
    Cheers,
    Tyler
    Aug 2008
    13
    i allso got the MC433 Motor Control rev 1.2
    never buy off ebay
    the board is not moveing the motor's they buzz like there not geting the right power i tested everything i played with the tuning
    i looked all over hopeing that the pin setup was off as that is what it seem's
    my pin set up is
    3 4
    5 6
    7 8
    im using mack 3
    all it do's is buzz motor's get very hot
    i am new seem's there is alote of bad Motor Controler's
    please can someone give me some name's of WORKING controlers
    this the sic brand i got that was a wast of $$$ my othere was the tb6560
    time do's not matter stoping it do's if you can stop time for one hour thin that hour would be forever
  1. Spindle quit running w/ c axix fault
    By TomCNC88 in forum Fadal
    Last Post: 07-28-2006, 04:07 PM
  2. New X2 up and running
    By mjarus in forum Benchtop Machines
    Last Post: 01-03-2006, 02:41 PM
  3. Running an ATC
    By chrisw765 in forum Mach Software (ArtSoft software)
    Last Post: 11-09-2005, 02:20 AM
  4. Up and running!
    By maxxgraphix in forum DIY CNC Router Table Machines
    Last Post: 03-16-2005, 02:10 PM
  5. up and running
    By corrie in forum CNC Wood Router Project Log
    Last Post: 10-02-2004, 08:31 PM
