585,729 active members*
4,895 visitors online*
    May 2016
    4
    Post HRT-210 ROTARY TABLE
    Couple years ago are HRT-210 rotary table was running just fine in are HAAS VF-3 VMC. When we got the a job done we took the rotary table out and put it storage. Now when we want to used it we're getting a alarm popping up (185- A cable fault). I check the setting 30 and it set for the HRT210.
    CAN ANYONE HELP ME OUT?
    THANKS,
    Nov 2006
    490
    Re: HRT-210 ROTARY TABLE
    Is it possible the A-axis parameters were altered between now and then? (perhaps during a software update?)
    May 2016
    4
    Only thing that got change on the CNC is setting 30, went from HRT-210 to OFF. For the software update we haven't had one done.
    Sep 2006
    251
    following.... I have the same scenario. any fix to this yet?
    Just a good ol' boy, never meanin' no harm.
    Joe
    Mar 2006
    48
    On my Haas when I remove the 4th axis or add it I go to setting #30,press the emergency stop button,cursor arrow to either off or to HRT-210 or HRT-210B(whichever you have) hit enter. Hook or unhook your 2 cables up outside of back cabinet. Take emergency stop off,hit reset,home axis. You should see that it found the (A) axis at the position window.
  1. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  2. CNC Rotary table
    By instructor37 in forum Shopmaster/Shoptask
    Last Post: 04-28-2010, 07:01 AM
  3. M32 VTC with rotary table
    By jimiscnc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-17-2009, 03:12 PM
  4. cnc rotary table
    By iccirvr in forum Benchtop Machines
    Last Post: 03-01-2008, 06:05 PM
  5. Looking for a rotary table
    By gto7419 in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2006, 01:37 AM
