585,676 active members*
3,947 visitors online*
Results 1 to 12 of 12
    Feb 2006
    49
    help repairing Anilam Crusader II control?
    Can someone give me some troubleshooting tips on a 1986 Anilam Crusader II control on a Lagun FTV-2 vertical mill? We just bought this for the iron, and planned to retrofit a new control, but this Crusader II powers up, reads the scales on each axis so we are seeing if we can bring it back to life and give it a try instead of jumping into the retrofit.
    The Crusader will let me manually jog the servo motors if I hold in the reset button on the back of the Crusader II control system. If I do not use the override, there is no motion.
    I pulled the boards from the controller and cleaned the edge connectors and reseated all the connectors and no change. I did not see and obviousliy blown componenets, but there were a few where heat had discolored the pcb under them.
    I have a nice wiring diagram of the amp box from Anilam, and can see the function of the override is to override a loop that contains the estop button, limit switches and thermal overloads in the amp. Pushing the override button allows 24vdc in this loop to pass through some relays and power up the servo amps and finally reach ground according to the diagram. The diagram shows a transistor in the Crusader II normally doing this task, but the override is available apparently to test the system to see if you have other problems.
    I decided to take a break and ask for help hoping someone will remember this problem. Next I was planning to trace through this amp enable loop and see how far the signal proceeds. My hunch is that the problem is in the Crusader control and it is not able to switch this transistor, and this would likely require replacement of one of the controller boards.
    I'm sure some of you guys have solved this problem before, so thanks in advance for any advice you can give me.
    Doug Danielson
    404 667 4680 mobile
    Atlanta
    Nov 2005
    28
    Have you got sorted out yet. I have all the wiring diagrams.
    Cheers Wallace
    Customer Service
    Hi Doug,
    You might want to call Tim Podgwaite Jr. the National Service Manager for Anilam. He is a super guy and he and others in the Anilams Service Department were "extremely" helpful in sorting out problems I had with my Anilam 1100M controller. His number is 1-716-661-1724.
    I don't know if they still offer any support for you particular model but he would be my number one choice to get the possible information to fix you controller.
    Hope this helps.
    John
    Apr 2006
    4
    Quote Originally Posted by kiwiavi View Post
    Cheers Wallace
    Could you send me copies of the wiring diagrams? Just drop me a PM and I can tell you my email address.
    TommyL.
    Nov 2005
    28
    My email is kiwiaviatxtradotcodotnz. Cheers Wallace
    Apr 2005
    460
    Anilam
    I wasen't so lucky with anilam I asked and they offered to sell me a update control for $7500.00 But I had a experance like this with my BPT the control will not G01X1.25Y1.55F100 Ect if the spindel is not active try that Good luck do you have the programing manuals that would be a great help Kevin
    Jan 2011
    Hi kiwiavi.
    I`m repairin a vertical boring machine with Anilam Crusader CNC.
    Can you send me the wiring diagrams you have ?
    Thanks in advance.
    Barto.
    Rosario, Argentina.
    Nov 2005
    28
    Send me you email address. marshland
    @ marshland dot co . nz
    Sep 2011
    5
    I have bought 2 CNC Machines with Brushed DC Servo motors Indramat MDC 10.20 a complicated DC Servo analog amplifier Indramat 3TRM2 the controllers is Anilam Crusader II L that is quite complicated. I don't have diagrams or technical data of the system. I want to run these machines can you suggest me where to start with?
    Currently I am planning to get some break-out servo board but confused how to get it done
    I have done some small projects for my own workshops and others, I know very little about CNC need help dear.
    Nov 2005
    28
    Send me me a few photos of the machine and I'll see if I can help.
    [email protected]
    If any one have the complete circuit diagram for indramat 3TRM2 servo amplifier, pl. email me.My email address is [email protected]
    regards,
    S.Kamalakannan
    regards,
    S.Kamalakannan
  1. Anilam Crusader II - Crusader 2 Training DVDs
    By Mike Mattera in forum News Announcements
    Last Post: 07-09-2007, 03:31 AM
  2. RS-232 / Dnc, Pc To Anilam Crusader 2 Anybody Doing It?
    By jpb6061 in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2007, 12:12 PM
  3. Anilam Crusader 2 Help
    By porsche1220 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-09-2006, 06:37 PM
  4. Anilam Crusader M
    By Tooler in forum BobCad-Cam
    Last Post: 07-08-2003, 04:57 AM
