585,883 active members*
4,924 visitors online*
    Jun 2010
    16
    Leaking Valves
    I work in a plant where we have several hydraulic systems. We always seem to be fighting hydraulic leaks. One system in particular we keep replacing o-rings between a valve with a DO5 pattern and the manifold block that it is sitting on with very limited success. Once we replace o-rings the leaks stop for a week or so then start dripping again. When we take the valves off to replace o-rings we often find the o-rings collapsed into the port. I am looking for suggestions to help solve this problem.
    Thanks in advance.
    David
    Mar 2008
    683
    Re: Leaking Valves
    Get a bore scope and check out the valve internals.
    Sep 2009
    27
    Re: Leaking Valves
    When you have the spool out of the valve body check for bore damage, bore scope works great for this. if there is room a good light works fine .Also check the spool for any damage especially around the edge of the o ring grooves. Something that works great for older hydraulic valves and other related equipment that uses o-rings is to switch to quad rings, most hydraulics supply shops have them.
    They have the same I.D/O.D sizes as regular O-rings the only difference is that O-rings have basically a single sealing face surface and quads have two.
    Quad rings are used in many new hydraulic controls.
    Hope this helps
  1. Replies: 5
    Last Post: 02-20-2016, 04:41 AM
  2. WHAT IS THIS?????? MAC VALVES INC. PART
    By cajun in forum CNC Machine Related Electronics
    Last Post: 07-11-2011, 09:36 PM
  3. Injection Valves
    By mroy0404 in forum Employment Opportunity
    Last Post: 08-24-2009, 04:43 AM
  4. Question about valves
    By Adaware in forum I.C. Engines
    Last Post: 02-21-2009, 10:30 PM
  5. Ball Valves
    By SIMONSIGNS in forum Mechanical Calculations/Engineering Design
    Last Post: 04-28-2006, 04:16 AM
