Hi all,
thanks for your inputs!
I considered supported round rails carriage, but as i mentioned in my first post, they are cheaper by themselves, but more expensive with shipping to where i live.
The rails i was aiming are those that you call square profile rails, as i've seen that they are the most precise and reliable.
I don't mean to build a CNC like a 3D printer, i'm well aware of the problems with the prusa-like chassis woble that would make it inneficient for a CNC.
If anything, it would be the other way around, i want to build my 3D printers as CNC, with a rigid frame
What i meant by swapping parts in and out was that if you guys consider that it's too ambitious to go for a full build, i could go for a smaller scale CNC for starters,
knowing that nothing would be lost afterwards!
I take good note of your warnings about ball screws , and it's a shame, since it seemed so nice!
I also take note about the nema17. I wanted to use those since i have seen many CNC builds using those (and even machining aluminium), but if they're too weak, i'll order nema23.
Are nema 23 enough?
When i mean cutting aluminium, i mean that i'd like to be able to do it, not that i need a machine that eats thick aluminium sheets all day. In fact, i have no plan to cut aluminium in a near future.
However, i'd like to have this option so that at least, i can make motor mounts, chariots, or other stuff to make the next CNC or improve this one later on!
So about the linear motion, would two rails suffice for the X axis?
I've seen a design with a fixed gantry that i liked a lot, because it seemed strong and stable.
I was planing a moving gantry at first (and it's not out of the table), but it seems more complex to do.
If the design can be kept simple, this is less failure points, right?
So for now, i would go with rails like those :
3D print parts cnc Kossel Mini MGN12 12mm miniature linear rail slide 1 Set=3pcs 12mm L 800mm rail+3pcs MGN12H carriage-in Linear Guides from Industry & Business on Aliexpress.com | Alibaba Group
I've found two good deals : one pair at 96$ with free shipping, or a set of 3 at 130$ including shipping.
So if i order those 2 times, i'd end up with 6 bars, and 12 chariots for around 260$, shipped.
If those sliders are confirmed as good as i've read, this is the first stuff i'd order.
With 6, i'd feel more confortable with a moving gantry : i'd use 2 per "foot" of the gantry, but perhaps this is overkill?
I've also seen those :
HIWIN Taiwan made 2pcs HGR20 L 1000 mm 20 mm linear guide rail with 4pcs HGH20CA or HGW20CA narrow sliding block cnc part-in Linear Guides from Industry & Business on Aliexpress.com | Alibaba Group
They are based on the same concept, but seems much beefier, and 1m long. But it would cost me 300$ for just a pair (150+150$ shipping!). I think i'll keep those in mind for a later build?
Then about the cutting bit, i'll probably start with a router. the dewalt model that everyone is using will probably be my choice. The machine will use linuxCNC, because i want it open source and open hardware as much as possible.
About the ballscrews here's another link :
BallScrew 1605 C7 SFU1605 Length600mm Rolled Ball screw with single Ballnut for CNC parts BK/BF12 standard end machined-in Ball Screws from Industry & Business on Aliexpress.com | Alibaba Group
Another question about those : if there are bad quality ballscrews, won't there be equally bad acme threaded rods?
I understand that this is a vital part of the system, so i don't want to screw up (no pun inteded ^^)
