585,973 active members*
4,175 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Preferred stepper motor shaft diameter
    May 2016
    15
    Is there a preferred shaft diameter. I have choices of 1/4 and 3/8 for a 570oz.in Nema 23.
    Adam
    Feb 2016
    381
    Re: Preferred stepper motor shaft diameter
    Preference would be either additional strength or to suit available couplings, 3/8 being around 10mm would be stronger and 6mm posdsibly more common for cheaper coupling.
  1. Nema 34 Motor Shaft Diameter
    By Bronx68 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-19-2013, 05:18 PM
  2. X3 Motor Shaft Diameter
    By pzzamakr1980 in forum Benchtop Machines
    Last Post: 12-26-2007, 10:55 PM
  3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
  5. turning motor shaft to smaller diameter
    By smoker in forum Material Machining Solutions
    Last Post: 03-09-2007, 04:56 AM
