Looking for a Edge Finder whats your recommendations Thanks Dave P
Haimer 3d taster. Great tool
Sent from my SM-G900T using Tapatalk
I use a $5 edge finder.. Works well, but I don't have a haimer, I think that's the one to get if you want to spend the money.
Sent from my SM-G900V using Tapatalk
Haimer...is the hands down favorite here. It makes set ups a breeze and stays dialed in for a long time as long as you don't snap the tip off. I have bought several for my pair here over the last couple of years and can attest to the fact that they bounce back from crashes quite well! Initial cost is a lot to swallow, but the refinement, speed and repeatabillity gained have made it well worth it.
I used to use a $10 wiggler type, but now I use the $30 electronic fowler, it works very well:
Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
Memorial day sale at eco: 25% off and free shipping makes this very cheap (codes DS531 and FF531).
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
I think Haimer is the way to go if you have the money, but if you want to go more traditional, Fisher makes a nice little conventional edge finder in the US:
MICRO EDGE FINDER | Brownells
Hermann Schmidt used to makes a really nice edge finder but no longer sells them I think.
I have used a mechanical edge finder for more than forty years. I am able to repeat edge locations to .0002" or better.
I use a Starrett 827A edge finder with good results. The trick for me with mechanical edge finders is to sight along the axis that is being measured to see maximum kick out.
Don
The bad news is that 7 probe tips cost less than the Haimer!
The good news is that with a Haimer you can set x/y/z with a single tool.
Tim
I use a mitutoyo and starett edge finder with good results. I'm planning on getting the Haimer eventually after I get a power draw bar.
After odd results, I found the fault to be a non-concentric probe tip on my Haimer. Apparently I failed to set/adjust the tip concentrically after the tip was replaced and a 0.020" error was introduced; wow.
After that, I spent some time with my Haimer and the manual, which by the way is a very poorly written manual for such an expensive instrument. I have great respect $$ for this instrument and recommend it.
Lesson learned; perform concentric check after tip replacement.
A question for all you Haimer users: What is the typical accuracy/repeatability you experience with the Haimer?
I calibrate probe cocentricity with a .0001" indicator and the Haimer is as repeatable to within the tolerances I can produce. The bigger issue is work holding,vice tram etc. when rotating a part 4-5 times. One of the speed benefits of the Haimer is not just edge finding, but dragging the probe across a top surface or vise jaw face to detrmine part flatness/perpendiculaity on a part before subsequent machining operations. Tramming a vise,center hole locating,flatness indicator etc., it's just a great all around tool. I do so many one-off setups, it really speeds things up. The huge face and analog guage makes indicating fast,and easy while standing far away from the part. Yes, the probe tips are $50.00, but I've over travelled other indicators and they end up in the trash can.
