586,000 active members*
4,772 visitors online*
Results 1 to 8 of 8
    Oct 2006
    6
    Lost fanuc 3T parameters
    We lost fanuc parameters on an old takisawa TC2, 1987 model cnc lathe.
    The motherboard developed a fault so we changed it to identical one (so we thought) .Taking good care not to loose the parameters by keeping the board with its own powersupply as we swapped them. But the good gentleman who
    sold it to us forgot to mention that the machine it game from was 6 station turret machine.So our machine only works to 6th station and then gets mixed up. Any Help is appreciated
    24221
    Did you not make a record of the parameters, even a hard copy list?
    There is not that many on a 3T.
    It is many years since I worked on a 3T, but IIRC there is 8 ROM ic's that may have to be transfered over to the new board.
    I don't think this will be an option or parameter issue.
    But if you are changing boards, you are either getting a different set of parameters or they all need re-loading.
    Fanuc or Dan Fritz here on the zone should be able to confirm this.
    Al.
    Albert E.
    Mar 2008
    Cant enter Diag Parameters in a Fanuc 3T
    I lost my parameters in a Fanuc 3T. Got my NC Parametes in but I cant get diag parameters to type in. They wont change. Can anyone help? Fanuc is saying its the Mother board but 2 techs done think so. Any Ideas from anyone?? Thanks Mike
    Oct 2007
    9
    Quote Originally Posted by rrbird76 View Post
    Mike:
    I have a Takasawa TS15 and I need the pc parameters. Did you get your machine running? Can you share the PC parameters with me?
    Thnaks,
    Hal in Arizona
    Oct 2007
    9
    Quote Originally Posted by erikturn View Post
    I have the same model Takasawa and lost the PC parameters. Do you have a copy and if so, can you share them with me? I only need the PC parameters from number 100 up.
    Thank you,
    Hal in Arizona USA
    Nov 2008
    37
    Maybe this link could be useful for another Fanuc FAQ http://cnctechlearn.blogspot.com
    Nov 2008
    37
    This also maybe useful http://cncfanuc.blogspot.com
    Sep 2014
    4
    Re: Lost fanuc 3T parameters
    We lost fanuc parameters on an old takisawa okeyama TS20 cnc lathe.1983 model fanuc 3t system system
    please help me
  1. Parameters lost Fanuc 0M
    By Milaublu34 in forum Fanuc
    Last Post: 06-12-2014, 01:15 PM
  2. fanuc 3m lost parameters
    By zosos in forum Fanuc
    Last Post: 10-28-2011, 09:16 PM
  3. Fanuc O-M lost parameters
    By macperfo in forum Fanuc
    Last Post: 03-27-2009, 12:47 AM
  4. Parameters lost in Fanuc OM
    By wicked_won in forum CNC Machining Centers
    Last Post: 03-27-2008, 10:50 PM
  5. Replies: 2
    Last Post: 02-08-2008, 09:00 AM
